![]() | Home > General > Park heater gizmo |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 97 ![]() ![]() ![]() |
eBay Item No. 124117320536. EBay item number
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Yes to our D3 and its very good as long as your fbh actually works as it should in normal conditions. |
Follow links
Ah, brilliant. Thanks.
Not built in.
OK, thanks bud. I'll try the fit tomorrow. |
Tried fitting the gizmo. Worked then stopped. I've been told to cut the 2 yellow wires on the burner. 😱
If the fitting instructions that come with it then cut it, it's an improved version of mine looking at it.
Oh They want you to cut the CAN bus wires. This will stop the car turning the heater on. Personally I wouldn’t.
If unlocking the car is upsetting the heater :
Leaving the canbus untouched. I don't have screen climate as mines a 2008.
