Home > General > Park heater gizmo
Toonraider
United Kingdom 2008 Range Rover Sport TDV6 HST Stornoway Grey
Park heater gizmo
eBay Item No. 124117320536. EBay item number
Has anyone fitted one of these?
Post #629874 Fri Jan 13 2023 12:01pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Yes to our D3 and its very good as long as your fbh actually works as it should in normal conditions.
Post #629878 Fri Jan 13 2023 5:11pm
Toonraider
Do you recall how you fitted it or have pics/ instructions by chance?
Fwiw, my heater does work spot on lol
Post #629880 Fri Jan 13 2023 6:51pm
Follow links
https://www.rrsport.co.uk/forum/topic57135.html
https://www.disco3.co.uk/forum/turning-fbh-191038.html
Post #629881 Fri Jan 13 2023 8:08pm
Toonraider
Ah, brilliant. Thanks.
Do these have a set run / cut off time.?
Post #629897 Sat Jan 14 2023 3:12pm
Not built in.
The heater itself must shut down when hot
Post #629902 Sat Jan 14 2023 3:55pm
Toonraider
OK, thanks bud. I'll try the fit tomorrow.
Post #629903 Sat Jan 14 2023 3:57pm
Toonraider
Tried fitting the gizmo. Worked then stopped. I've been told to cut the 2 yellow wires on the burner. 😱
Is that correct advice?
Post #630000 Tue Jan 17 2023 10:33pm
Lrstaylor
If the fitting instructions that come with it then cut it, it's an improved version of mine looking at it.
If it doesn't work then just reconnect the yellow wire back again
Post #630002 Tue Jan 17 2023 10:48pm
Oh They want you to cut the CAN bus wires. This will stop the car turning the heater on. Personally I wouldn’t.
It is stopping when you unlock the car or open door?
Without touching the remote one morning, check heater is still working by starting car at 4C or below.
Ensure climate control panel is ON
Post #630004 Wed Jan 18 2023 6:52am
If unlocking the car is upsetting the heater :
People recommend :
1 Turn the remote heater off ~2 mins before you unlock car. To allow heater to shut down and be ready to restart with engine
2 if you forget to do the above and confuse the system. Turn the climate control panel Off then On while engine running.
You are meant to turn the remote heater off at some point. By pressing button A or B depending how it is configured. What do instructions say? Test by listening to the relay click or put an led light (yellow) in the grill connect to the blue wire.
If you don’t turn the remote off before unlocking car. Then turn it off at the end of journey.
Post #630005 Wed Jan 18 2023 7:12am
Toonraider
Leaving the canbus untouched. I don't have screen climate as mines a 2008.
Seems to be working OK now that I've actually pressed the off button before starting her up.
Post #630073 Fri Jan 20 2023 8:09pm
