Home > General > Set gearbox to neutral for recovery? |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
There are posts on here about issues with the selector but if you have a non-starter it's probably not that. Should the rotary selector rise if you cycle the ignition without your foot on the brake? Just a thought, I don't know because mines the 6 speed.
Sun Nov 06 2022 10:55am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5007 |
you need to pull a bit of string.
Sun Nov 06 2022 11:13am |
AbioRRS Member Since: 02 Oct 2022 Location: Scotland Posts: 5 |
Thank you both
Sun Nov 06 2022 11:21am |
Arh, sorry.
Sun Nov 06 2022 11:58am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
Should be something that looks like this under the transmission tunnel console cup holder, similar to that shown in the posted video.
Sun Nov 06 2022 1:29pm |
That's great, thanks. I was aware of that for the rear brakes but never knew it also did the transmission.
Sun Nov 06 2022 6:56pm |
It's not actually the same one as for the park brake release, that is a separate cable tucked away there somewhere.
Sun Nov 06 2022 8:33pm |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 |
You should get yourself a download of the service manual, a very valuable bit info for us RRS owners...i'm sure you'd be able to pick up a copy here somewhere, on the Forum that is. |
Tue Nov 08 2022 5:38pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9010 |
Workshop manual: https://www.mediafire.com/file/yunzrqm47py...6.pdf/file
Tue Nov 08 2022 5:44pm |
Thank you all once again
Wed Nov 23 2022 8:49am |
