![]() | Home > General > Set gearbox to neutral for recovery? |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 780 ![]() ![]() ![]() |
There are posts on here about issues with the selector but if you have a non-starter it's probably not that. Should the rotary selector rise if you cycle the ignition without your foot on the brake? Just a thought, I don't know because mines the 6 speed.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5027 ![]() ![]() ![]() |
you need to pull a bit of string.
AbioRRS Member Since: 02 Oct 2022 Location: Scotland Posts: 5 ![]() ![]() |
Thank you both
Arh, sorry.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5052 ![]() ![]() ![]() |
Should be something that looks like this under the transmission tunnel console cup holder, similar to that shown in the posted video.
That's great, thanks. I was aware of that for the rear brakes but never knew it also did the transmission.
It's not actually the same one as for the park brake release, that is a separate cable tucked away there somewhere. |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 ![]() ![]() ![]() |
You should get yourself a download of the service manual, a very valuable bit info for us RRS owners...i'm sure you'd be able to pick up a copy here somewhere, on the Forum that is. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9041 ![]() ![]() ![]() |
Workshop manual: https://www.mediafire.com/file/yunzrqm47py...6.pdf/file
Thank you all once again
