Home > Technical > 4.2 Supercharged PCV System
Page 2 of 3 <123>
dhallworth
Smoke tester finished this evening. Resistance wire wrapped around the wick and then fitted into the pot.
12v feed now wired into the sides.
Baby oil now added to the mixture.
Whoever at Amazon packed this box - torch wicks, 12v cable with crocodile clips, resistance wire and baby oil would be as confused as hell Laughing
Quick zap with 12v to ensure that we got smoke…
Quick puff of the lungs to see the result of the smoke machine:
I then connected it to the airline and fed it with 10PSI and saw a leak.
This makes perfect sense as it’s leaking right by cylinder 1. It’s cylinder 1 that logs most of the misfires when cold on the diagnostics. The only thing I can think of down there is the adapter plate that houses the injectors and sits between the charge coolers and the cylinder head.
Am thinking of tearing the whole lot down, and replacing all of the gaskets including the valve cover ones whilst it’s in pieces.
A job I could do without doing but hey ho.
David. 2002 Range Rover 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior
Post #623891 Wed Apr 27 2022 8:34pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Nice find, I'm replacing the pcv shortly. New plugs are fitted misfire counts drastically reduced but the engine was getting warm by then sooooo let's see. I'm sure there is a vacuum leak so will need to smoke test as well I'm going to be using a glow plug in my DIY smoke machine.
Have reset the engine adaptations and was better on a test drive, this and the front snout bearing replacement are hopefully the last jobs on my list.....oh top up the gearbox after finding and fixing the gearbox oil leak new oil arrived today.
Post #623893 Wed Apr 27 2022 8:55pm
Lrstaylor
I'm gsxr1250dave by the way Razz
Post #623894 Wed Apr 27 2022 9:00pm
mgrover
Whilst the super charger is torn down might be worth upgrading the pulley. Maybe also checking out your fuel injectors and the seals.
Also there's a host of sensors down there
Post #623899 Thu Apr 28 2022 7:17am
dhallworth
Do you know what sensors are down there?
I’ve ordered a bearing kit for the charger, and am ordering all the gaskets from the charger down to the heads including all the o-rings for the injectors.
I’ve been thinking about a 10% pulley but can’t be bothered with machining the snout to fit it.
Post #623902 Thu Apr 28 2022 11:04am
mgrover
atleast the MAP sensor, knock sensors, air temp sensor I think.
6% doesnt need machining if i remember rightly, got mine done by the nice people at
https://powerhouse.uk/supercharger-perform...r-pulleys/
i live closer so I drove down, swapped it there and then and went back.
Post #623903 Thu Apr 28 2022 11:17am
dhallworth
Aren’t those sensors down the back of the engine? My smoke leak is at the OS front corner right beside cylinder 1. 2002 Range Rover 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #623904 Thu Apr 28 2022 11:28am
While the SC is off, check/replace the plastic coolant pipes
Post #623906 Thu Apr 28 2022 11:33am
mgrover
They are but since the SC is off it makes life easier.
Post #623907 Thu Apr 28 2022 11:49am
dhallworth
This is underneath my Supercharger when it was removed last year.
The pipes under mine are rubber so I wonder if they've already been changed at some point.
Post #623908 Thu Apr 28 2022 11:49am
mgrover
id say while its out, close up the intake holes with duct tape and test again
these were picks from last time i did it
https://photos.google.com/share/AF1QipNFhw...VseXRsVGN3
yours sound like maybe valve cover gasket or something else that way.
Post #623909 Thu Apr 28 2022 11:59am
dhallworth
Thanks Guys Smile
I've got valve cover gaskets and the o-rings that go around the plugs already. Am about to order the rest of it so I've got it and at least then I can replace it all.
Plan is to remove the charger and then attach smoke tester to the charge cooler as that should then give me a better view of where it's leaking on that side.
Valve cover gaskets on the NS bank (even cylinders) say to discharge the air conditioning in the workshop manual. With the charge cooler out of the way I think I should be able to slide it up without touching the air con pipes so it makes sense to tackle it all in one go I reckon.
Here's what I'm ordering this afternoon.
The only bits I'm not ordering are the gaskets between the charge coolers and the plate that goes on top of the charger as they're expensive, don't appear to be leaking and are easy to get to, and the one that lives on top of the charger as that was new only a few months ago.
Post #623912 Thu Apr 28 2022 12:05pm
mgrover
one thing, the valve cover gasket seems a bit short for me, so I cut some from the old gasket and merged together with gasket maker.
actually before you do, i have the elbow gasket and all the fuel seals if ya fancy em? Razz i got em and never ended up fitted them
Post #623913 Thu Apr 28 2022 12:08pm
dhallworth
Thanks for the offer Smile
I'm really hoping to get this lot finished at the weekend so I've just ordered all of them from the local dealer for collection tomorrow morning.
Post #623914 Thu Apr 28 2022 12:12pm
mgrover
fair enough, i might have to get off my backside and fit em, but currently got a new shiny project in an E39 M5, and the bikes are requiring some time Razz
But tbf getting the Duc ready for the NC500 soon
Post #623915 Thu Apr 28 2022 12:15pm
Page 2 of 3 <123>
