![]() | Home > Technical > 4.2 Supercharged PCV System |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 352 ![]() ![]() ![]() |
Nice find, I'm replacing the pcv shortly. New plugs are fitted misfire counts drastically reduced but the engine was getting warm by then sooooo let's see. I'm sure there is a vacuum leak so will need to smoke test as well I'm going to be using a glow plug in my DIY smoke machine.
I'm gsxr1250dave by the way |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
Whilst the super charger is torn down might be worth upgrading the pulley. Maybe also checking out your fuel injectors and the seals.
dhallworth Member Since: 14 Aug 2015 Location: Glasgow Posts: 48 ![]() ![]() |
Do you know what sensors are down there?
atleast the MAP sensor, knock sensors, air temp sensor I think.
Aren’t those sensors down the back of the engine? My smoke leak is at the OS front corner right beside cylinder 1. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5105 ![]() ![]() ![]() |
While the SC is off, check/replace the plastic coolant pipes |
They are but since the SC is off it makes life easier. |
This is underneath my Supercharger when it was removed last year.
id say while its out, close up the intake holes with duct tape and test again
Thanks Guys |
one thing, the valve cover gasket seems a bit short for me, so I cut some from the old gasket and merged together with gasket maker.
Thanks for the offer |
fair enough, i might have to get off my backside and fit em, but currently got a new shiny project in an E39 M5, and the bikes are requiring some time |
