Home > Technical > 4.2 Supercharged PCV System |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
Nice find, I'm replacing the pcv shortly. New plugs are fitted misfire counts drastically reduced but the engine was getting warm by then sooooo let's see. I'm sure there is a vacuum leak so will need to smoke test as well I'm going to be using a glow plug in my DIY smoke machine.
Wed Apr 27 2022 8:55pm |
I'm gsxr1250dave by the way |
Wed Apr 27 2022 9:00pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
Whilst the super charger is torn down might be worth upgrading the pulley. Maybe also checking out your fuel injectors and the seals.
Thu Apr 28 2022 7:17am |
dhallworth Member Since: 13 Aug 2015 Location: Glasgow Posts: 40 |
Do you know what sensors are down there?
Thu Apr 28 2022 11:04am |
atleast the MAP sensor, knock sensors, air temp sensor I think.
Thu Apr 28 2022 11:17am |
Aren’t those sensors down the back of the engine? My smoke leak is at the OS front corner right beside cylinder 1. 2002 Range Rover 4.6 Vogue SE - Alveston Red with Lightstone Leather
Thu Apr 28 2022 11:28am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4996 |
While the SC is off, check/replace the plastic coolant pipes |
Thu Apr 28 2022 11:33am |
They are but since the SC is off it makes life easier. |
Thu Apr 28 2022 11:49am |
This is underneath my Supercharger when it was removed last year.
id say while its out, close up the intake holes with duct tape and test again
Thu Apr 28 2022 11:59am |
Thanks Guys
Thu Apr 28 2022 12:05pm |
one thing, the valve cover gasket seems a bit short for me, so I cut some from the old gasket and merged together with gasket maker.
Thu Apr 28 2022 12:08pm |
Thanks for the offer
Thu Apr 28 2022 12:12pm |
fair enough, i might have to get off my backside and fit em, but currently got a new shiny project in an E39 M5, and the bikes are requiring some time
Thu Apr 28 2022 12:15pm |
