Home > Maintenance & Modifications > Replacement Dynamic pipes question.
Page 1 of 3 123>
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I have been reading about Dynamic response pipes , front, and come to the conclusion that most folk , send to a garage to get replaced , Part NRQA500120
Has anyone got a way out of the corrosion problem by way of an aftermarket replacement kit. Apart from saving up £339 to replace the front pipes and to fit yourself the added issue of raising the body , this all seems to be a bit much. At present I have a very small leak on one the front pipes at a bracket and without investigating further , I wish to leave alone.
I understand the front section can be split into two part numbers but I would stick with the front 4 pipes . Reports of this new assembly is very difficult to replace . Any thoughts , trying to DIY this as usual.
Post #622741 Sat Mar 12 2022 7:58pm
Disco_Mikey
Separate the body. Support the body on axle stands and lower the chassis on jacks
With a bit of forward planning, it's not as daunting as it first seems
Getting the pipes out the valve block can be a challenge though...
Post #622750 Sun Mar 13 2022 7:27am
Oldandconfused
Brit Plumber did a repair using high pressure fixings, not sure if you feel confident doing it yourself, and I doubt you would get a garage to do it.
https://www.rrsport.co.uk/forum/topic56134...ace+pipes;
Post #622761 Sun Mar 13 2022 10:01am
alfapat
If its a garage doing this how long does it take I am thinking hourly or days? Ill begin saving !
Looking now for a guide for body lift. After I get my MOT AT THE END OF THE MONTH.
Post #622764 Sun Mar 13 2022 11:26am
Disco_Mikey
We turn them around same day, barring any unforseen issues. Allow for 8 hours Thumbs Up
Post #622765 Sun Mar 13 2022 11:39am
alfapat
I was hoping you would say that as I could make that to yourself in a day once I have resources . Or I get brave enough through the summer and DIY., if it lasts that long ! tHANKS
Post #622767 Sun Mar 13 2022 12:56pm
Rowdie
Re dynamic pipes
Question for you experts please, when separating the body from the subframe, does the tracking need redoing afterwards?
Post #622801 Mon Mar 14 2022 7:59pm
Disco_Mikey
No Thumbs Up
Post #622805 Mon Mar 14 2022 8:50pm
alfapat
Re: Re dynamic pipes
Would anyone know of a guide to a partial lift of the body on v8 diesal
Post #622925 Fri Mar 18 2022 3:12pm
Disco_Mikey
An hours subscription to Topix Thumbs Up
Post #622934 Fri Mar 18 2022 7:08pm
alfapat
OK , thanks I have tried in the past to get a login to Topix and failed and still failing.
I have tried INDEPENDANT LOGIN but very unsuccessful.
So bit stuck on that one , you say you might have stock of the front pipes for Sport v8 3.6 or maybe not , what price would you sell for or what price can I expect to pay for the job.
Thank you for your help meantime.
Post #622945 Sat Mar 19 2022 9:59am
Disco_Mikey
We have stock on the newer part number, LR015144
Retail at £305 + VAT
I expect RQA500120 will be obsolete, and supercede to the above number Thumbs Up
Post #622952 Sat Mar 19 2022 3:00pm
alfapat
Thanks Mikey, Ill make enquiries locally, incidentally read your guide on here , was thinking that apart from removing wheel arch bit and bobs to reach body mounts to slacken doesn't seem too bad to raise 2 inches , would that be right. I also watched a video on that thread, shame I have a 4 post and not a 2 post, but hey ho I'm lucky to have that.
Post #622958 Sun Mar 20 2022 9:44am
alfapat
Best tool to get at front dynamic feed pipe with torque tool , as my 10mmx75mm long 20 torx is broken I'm struggling, extremely tight and little room .
Post #623943 Fri Apr 29 2022 12:49pm
alfapat
It's OK, short tox bit and 10mm spanner, with a bit of Freeze and release!
Now next up one of the mountbolts (third one back from front)has rounded , suggesyion I have is to weld a nut to it , I ve tried hex and downsize sockets etc, anyone had this , thing is I risk destroying the mounting bush with heat, not too much of a loss. Ideas appreciated.
And thirdly on going,
Are these little dampers in the front wheel arch important , one I have is siezed.
Post #623944 Fri Apr 29 2022 3:51pm
Page 1 of 3 123>
