Home > Faults & Fixes > Tdv6 restricted performance turbo inlet valve problem!!!!!
pomistea
Ireland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
How did you get on with this problem?
Post #632371 Sat Apr 15 2023 6:16pm
Klingerl
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Lux Chawton White
With the info from all with the same problem I started looking at the vacuum lines that control the turbo gate valve
I found the plastic T piece that supplies the turbo gate valve had cracked reducing vacuum pressure.
please see pics below
I replaced the plastic one with a brass one as i don't want to see this again
Post #632380 Sun Apr 16 2023 8:30am
pomistea
Hey-
Thanks for replying.
Could you take a look at this thread, please?
I think you might be able to help me.
https://www.rrsport.co.uk/forum/topic60878.html
-Thanks
Post #632381 Sun Apr 16 2023 8:31am
pomistea
Sorry, I don't see any pics?
Post #632383 Sun Apr 16 2023 8:53am
Klingerl
hit the gallery
I just tried and they were there
Post #632385 Sun Apr 16 2023 9:51am
pomistea
Oh sorry, I didn't know about the gallery button.
Okay, even I should be able to find that, I'll check now, thank you.
Post #632396 Sun Apr 16 2023 3:39pm
Liviunicolas
Romania 2010 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
hi scotty i have the exact same codes.. i didn't understand exactly which pipe you are referring to?
Post #642440 Wed Jun 05 2024 4:05pm
pomistea
Stand in front of the car, to the left, facing the steering wheel.
See at the back of the engine bay, closest to the steering wheel, there's a plastic cover under the windscreen wiper. There are air lines running in there and across from there towards the right. Check them, particularly the joints. The plastic connectors can get very brittle over time and are likelier to be leaking that the hoses themselves.
Honestly though mate, I was in the exact same place as you this time last year. I hoped for a win, i.e. to find a leaking hose rather than a leak in an intake manifold but no such luck. I found a broken hose and replaced it but the fault remained. I took the MAF sensors out and cleaned and tested them, to no avail. I arsed around for ages and eventually made my own smoke machine, tested and as expected, saw smoke coming out of an intake manifold. Cracked manifolds are very common and unfortunately that's probably what you're looking at here, though you never know.
They're a pain to get at too, so if you do have to replace then replace both the left and right ones.
Here's a link to one of the many threads in the FB group about failed intakes.
https://www.facebook.com/groups/1650920707...960853303/
Post #642461 Thu Jun 06 2024 1:39pm
Liviunicolas
@pomistea did you have the same error codes? i.e. p22d2 and p22cf? and in the end were the broken intake manifolds to blame?
Post #642463 Thu Jun 06 2024 2:54pm
pomistea
Hi-
Yes. The left intake manifold was cracked, air (boost pressure) was escaping through it and this was causing the error codes and putting the car into Restricted Performance.
I replaced both intake manifolds and the car has been running perfectly since.
Post #642464 Thu Jun 06 2024 3:00pm
Liviunicolas
this is probably the same for me. I can also hear how it loses air when I accelerate
Post #642465 Thu Jun 06 2024 3:03pm
pomistea
I think the only way to be certain is if you get it smoke tested. I was able to make one that just about worked well enough for me to see smoke coming out of the side of the intake manifold.
Post #642466 Thu Jun 06 2024 3:05pm
Liviunicolas
@pomistea were the error codes the same p22d2-77 and p22cf-71?
Post #642467 Thu Jun 06 2024 3:05pm
pomistea
Hi-
I was, I think, getting P22CF-71 and P22D4-14.
See here - https://www.rrsport.co.uk/forum/topic60878.html
Post #642468 Thu Jun 06 2024 3:10pm
