![]() | Home > Faults & Fixes > Tdv6 restricted performance turbo inlet valve problem!!!!! |
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 43 ![]() ![]() ![]() |
How did you get on with this problem? |
Hey-
Sorry, I don't see any pics? |
Klingerl Member Since: 23 May 2021 Location: Queensland Posts: 5 ![]() ![]() ![]() |
hit the gallery
Oh sorry, I didn't know about the gallery button.
Liviunicolas Member Since: 05 Jun 2024 Location: Bacău Posts: 5 ![]() ![]() ![]() |
hi scotty i have the exact same codes.. i didn't understand exactly which pipe you are referring to? |
Stand in front of the car, to the left, facing the steering wheel.
@pomistea did you have the same error codes? i.e. p22d2 and p22cf? and in the end were the broken intake manifolds to blame? |
Hi-
this is probably the same for me. I can also hear how it loses air when I accelerate |
I think the only way to be certain is if you get it smoke tested. I was able to make one that just about worked well enough for me to see smoke coming out of the side of the intake manifold. |
@pomistea were the error codes the same p22d2-77 and p22cf-71? |
Hi-
