Home > General > DRL For L320 Autobiography
Page 3 of 3 <123
RRSSDDUB
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Fuji White
ah ok Taff, well if its any consolation its rather cold here Very Happy
Post #613120 Fri Apr 30 2021 1:38pm
Brit Plumber
I fitted these to my AB a few years ago, take the bumper off of you intend to do it. The covers are held on with spring clips and pulling the cover will simply pull the little tabs off and they will never fit again.
I wired mine in slightly different to the instructions. Instead of them going off with the side lights coming on, I wired them to go off with the main beams. That way I have the DRL and fairly lights together.
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #613126 Fri Apr 30 2021 8:23pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Yes mine came with a control module that gave the same option to go off with headlight or sidelights depending on how you wired them but i didnt want them to go off at all so i bought a new dimmer module off amazon only about £12 this then dimmed the drl 50% when dipped come on so you can have drl on with sidelights and drl would be at 100% brightness but as soon as dipped is switched on drl still stay on but at 50% as mentioned.
This module also keeps the drl on when you lock the car so they become welcome home lights and lights have used the ignition feed in the headlight for drl activation so the drl come on as soon as you unlock the car making them welcome lights and home lights, So my advice is to buy one of these dimmer modules of ebay/amazon and do the same you get alot more features out of your drl’s then.
Post #613128 Fri Apr 30 2021 8:35pm
Just out of interest, does the A/B not have approach lights in the mirrors as standard or was it a option?
Post #613129 Sat May 01 2021 12:05am
Taff814
United Kingdom 2005 Range Rover Sport TDV6 HSE Orkney Grey
RRSSDDUB wrote:
Taff i have been looking at these ones also - does anybody know if on 2012 autobiography the fog light surrounds just pull off or is it a bumper off job?
How did your fitting go taff?
I'm still stuck in Saudi. Managed 30 days in the UK since Dec 19 and I was in isolation and lockdown for 26 of those!!!
If i ever get back I'll let you know
Post #616108 Sat Jul 24 2021 3:30pm
chilly
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Are yours the proper Land Rover ones?
Mine have broke the module on them burnt out and popped one of the bulbs so going to order new set but would like mine to stay on all time so I was just not going to wire into the side lights.
But if they dimmed that would be good.
What kit do I need for that only the dead truely know peace,
Bootneck its not a job its a way of life!
Post #622117 Mon Feb 21 2022 7:29pm
Page 3 of 3 <123
