Home > General > DRL For L320 Autobiography |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 472 |
So does anyone have the factory DRL's fitted?
Wed Feb 24 2021 9:09pm |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 228 |
They do look nice and quite easy to install, I would like these to replace fogs and have the factory drl led strip in the lower grill section that would give plenty of light 😃 |
Wed Feb 24 2021 9:18pm |
So i have bought these as they have 4 leds which hopefully will match the standard factory look, These are very bright i temporarily wired them to my battery, these definitely need to go off when headlights come on as they’re too bright for night driving. Does anyone know if these can be dimmed using the control boards you can buy to wire drl to dipped beam so they then stay on but low like the signature led’s look?
Tue Mar 02 2021 8:15pm |
Just wondering if anyone has these fitted?
Tue Mar 02 2021 8:30pm |
RRSSDDUB Member Since: 31 Mar 2021 Location: NE Posts: 28 |
any updates on this thread - any pictures of completed ???? |
Mon Apr 12 2021 10:10pm |
I ended up fitting the osram drl’s as these look better quality build and still have the 4 leds to keep the factory drl look. Also i have the 2in1 powerful uk fogs which are very similar to the signature leds in the headlights so help blend it all together imo, the picture doesnt look the best with iphone but you get the idea, My drl come on once opened the car like welcome lights and stay on until you lock the car, once dimmed lights are turned on then drl dim 50% the 2in1 leds come on with sidelights.
Mon Apr 12 2021 10:36pm |
thanks - they look really good and certainly bright enough to be be DRLs!!!!! |
Tue Apr 13 2021 1:11pm |
They’re and because they’re low enough i dont get anyone flashing to say they blind them but have the effect wanted still. |
Tue Apr 13 2021 1:46pm |
Taff814 Member Since: 19 Dec 2020 Location: Dereham Posts: 11 |
I've bought the 2 in 1 fog/DRL set from Powerful for my 2005 RRS. If I ever get out of Saudi and get them fitted I'll put some pics up |
Mon Apr 26 2021 3:01am |
Taff i have been looking at these ones also - does anybody know if on 2012 autobiography the fog light surrounds just pull off or is it a bumper off job?
Fri Apr 30 2021 8:43am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5024 |
If I remember correctly the bezels are just held in with spring clips and can be popped out, but you still need to remove bumper to change lamps as held in with three screws from the back.
Fri Apr 30 2021 9:42am |
thanks, I watched a guide that said for pre 2010 models the plastic trims pop out and the lights can be changed by wiggling them out with bumper on....not sure if it is the same for 2012 autobiography? |
Fri Apr 30 2021 10:25am |
Would have thought it was just as easy to take the bumper off, easy enough and not a long job.
Fri Apr 30 2021 10:44am |
Sadly I'm still in Saudi. Might get home this year to do them...or maybe not |
Fri Apr 30 2021 11:22am |
