Home > General > DRL For L320 Autobiography |
RRSSDDUB Member Since: 31 Mar 2021 Location: NE Posts: 28 |
ah ok Taff, well if its any consolation its rather cold here |
Fri Apr 30 2021 12:38pm |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 226 |
Yes mine came with a control module that gave the same option to go off with headlight or sidelights depending on how you wired them but i didnt want them to go off at all so i bought a new dimmer module off amazon only about £12 this then dimmed the drl 50% when dipped come on so you can have drl on with sidelights and drl would be at 100% brightness but as soon as dipped is switched on drl still stay on but at 50% as mentioned.
Fri Apr 30 2021 7:35pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5001 |
Just out of interest, does the A/B not have approach lights in the mirrors as standard or was it a option?
Fri Apr 30 2021 11:05pm |
Taff814 Member Since: 19 Dec 2020 Location: Dereham Posts: 11 |
I'm still stuck in Saudi. Managed 30 days in the UK since Dec 19 and I was in isolation and lockdown for 26 of those!!! If i ever get back I'll let you know |
Sat Jul 24 2021 2:30pm |
chilly Member Since: 07 Dec 2010 Location: north east Posts: 192 |
Are yours the proper Land Rover ones? Mine have broke the module on them burnt out and popped one of the bulbs so going to order new set but would like mine to stay on all time so I was just not going to wire into the side lights. But if they dimmed that would be good. What kit do I need for that only the dead truely know peace, Bootneck its not a job its a way of life! |
Mon Feb 21 2022 6:29pm |
