Home > General (L494) > preventative maintenance
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Hi, just doing a bit (a lot) of reading up on the crankshaft fails on the 3.0 sdv6 engines on these cars. Can this happen to any 3.0, any year model, any mileage or is it a certain model year? Is there any preventative maintenance to do to avoid this? My car is 15 plate 2016MY and is on 41000 miles and has been faultless so far......Are LR aware of this happening?
Post #610431 Tue Feb 23 2021 8:54am
riverblanche
Hi,
stop reading you will get paranoid,
but
yes, yes, yes, no, no not really and yes they do but they wont admit it
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #610464 Tue Feb 23 2021 4:55pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
Re: preventative maintenance
You might benefit -reduce the risk- from oil changes every 6000 mls with the right oil 5W30 WSS–M2C934–B. (a so called C1 oil) RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #610469 Tue Feb 23 2021 5:30pm
Dave-t
There is no evidence that more frequent oil changes help at all. It is more important to keep a healthy oil level Joined the X5 45e club
1994 Defender 90 300 tdi
Post #610472 Tue Feb 23 2021 6:26pm
Johnrrs
Mmm you’re right . No point worrying about it until it happens, if it ever does.... Thumbs Up Thumbs Up
Post #610476 Tue Feb 23 2021 8:14pm
Dave-t
Just try and find a warranty that would cover the engine......there is another post somewhere, it’s not as easy as it used to be Joined the X5 45e club
Post #610480 Tue Feb 23 2021 8:52pm
Hog
There seems to be a relationship between the right oil, long oil change periods, oil dilution and the life span of the DPF. Not all particles will be burned during regenerations. The SAP elements in the oil will build up. This will over the years result in Increasing DPF pressure , more frequent regens and stress on the engine.
Shorter oil change periods and the right spec oil will help to keep the engine (and the turbo's!) healthy and might reduce the risk of a crankshaft failure. This is not hard evidence, but common technical sense. RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Post #610524 Wed Feb 24 2021 11:55am
harisson
Switzerland
It's a good question and you will not get an answer, which will be "the answer". That means: yes, more oil changes can help to avoid it, but you have no guarantee.
I ended with selling my wonderful Firenze red RRS with 78000km because of the possibility of this issue.
I couldn't arrange myself to agree the possibility of a crankshaft issue. I wouldn't sell it, if the issue was not "high frequent" and through all model years. Range Rover Sport HST D350
Post #610565 Wed Feb 24 2021 8:48pm
Ash3
Would DPF flssh clean help reduce regen frequencies?
Ie remove DPF..flash clean and put back on.
Post #610572 Wed Feb 24 2021 9:23pm
Disco_Mikey
We look after a lot of 3.0 models now. We've replaced a few engines, but these have all been on cads we haven't looked after previously, and every one has been low on oil when recovered in...
We have not had an engine failure on any 3.0 we have serviced as per the JLR schedule Thumbs Up
Post #610574 Wed Feb 24 2021 9:30pm
Ash3
Cool..
But what are your views DPF clean?
Will that reduce number of regens?
Post #610577 Wed Feb 24 2021 10:17pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Interesting comments Mickey.
I have just had the oil level sender in the sump replaced under warranty on my 2017 L494 last month.
I noticed that I could not pull up the oil level info on the screen.
Clearly if this sender fails due to oil incursion into the wiring you have no way of checking the oil level.
Plenty written about the lack of a dipstick!
Anyway it is possible this failure could lead to a low oil level with no indication to the owner and engine failure?
Could this be the indirect cause of the crank failures?
To remove the sump to replace the unit and wiring LR Artarmon NSW moved the front diff forward, is this the standard procedure?
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #610579 Wed Feb 24 2021 10:53pm
harisson
Switzerland
@Disco_Mikey
Sounds interesting.
I checked very often the oil level - every 10 days approx. I also took care to have it on max. Honestly - my L494 haven't took any drop of oil. The oil dilution message popped up once.
I took care to take it on longer journeys, to fill in premium Diesel without FAME etc.
At the end I took the decision to sell it. Was a great car during my ownership and I loved to drive it, but I couldn't handle the possibility of a broken crankshaft on my holiday journey with a 2 year old child in the car..
Now, I switched to Volvo. With the new D300 and D350 in the L461 I see a possibility to come back to the RR community Smile the new six-inline Diesel engines should be awesome.
Post #610612 Fri Feb 26 2021 6:21am
RugHead
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
A local Landover jaguar dealership, have just got in a new discovery 3.0 with a snapped crank, on a grand mileage of 64 miles.
Post #610630 Fri Feb 26 2021 1:31pm
