![]() | Home > General (L494) > preventative maintenance |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
You might benefit -reduce the risk- from oil changes every 6000 mls with the right oil 5W30 WSS–M2C934–B. (a so called C1 oil) RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
There is no evidence that more frequent oil changes help at all. It is more important to keep a healthy oil level Joined the X5 45e club
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
Mmm you’re right . No point worrying about it until it happens, if it ever does.... |
Just try and find a warranty that would cover the engine......there is another post somewhere, it’s not as easy as it used to be Joined the X5 45e club
There seems to be a relationship between the right oil, long oil change periods, oil dilution and the life span of the DPF. Not all particles will be burned during regenerations. The SAP elements in the oil will build up. This will over the years result in Increasing DPF pressure , more frequent regens and stress on the engine. Shorter oil change periods and the right spec oil will help to keep the engine (and the turbo's!) healthy and might reduce the risk of a crankshaft failure. This is not hard evidence, but common technical sense. RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
harisson Member Since: 28 Jun 2018 Location: CH Posts: 184 ![]() ![]() |
It's a good question and you will not get an answer, which will be "the answer". That means: yes, more oil changes can help to avoid it, but you have no guarantee.
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Would DPF flssh clean help reduce regen frequencies? Ie remove DPF..flash clean and put back on. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4442 ![]() ![]() ![]() |
We look after a lot of 3.0 models now. We've replaced a few engines, but these have all been on cads we haven't looked after previously, and every one has been low on oil when recovered in...
Cool..
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Interesting comments Mickey.
@Disco_Mikey
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 ![]() ![]() ![]() |
A local Landover jaguar dealership, have just got in a new discovery 3.0 with a snapped crank, on a grand mileage of 64 miles. |
