Home > General > New Buyer |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The V6 diesel has issues of its own. It doesn't have the turbo issues of the TDV8 but the TDV8 doesn't suffer from spun crankshaft bearings or snapped cranks. The TDV6 does suffer from the crossover pipe splitting - this is a body off job. My SDV6 recently required this doing and the bill was £1660 including replacing the rear brake lines (a body off job normally so worth doing when the body is already off) and the ARB bushes (because they're a job of minutes with the body off.
Thu Nov 19 2020 3:30pm |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 221 |
I got all the information I needed from here and went for the TDV8 , absolutely love it best MPG solo 32 towing the caravan 22 & average around 24 on pottering about.
Thu Nov 19 2020 3:35pm |
Ossie 1982 Member Since: 19 Nov 2020 Location: Worcester Posts: 4 |
Thanks for tips and advice. Will have a look to see if any TDV8's around, ones I've seen have all been the TDV6. Thanks again. |
Thu Nov 19 2020 5:08pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4999 |
I think there is a modification for the 3.0 V6 turbo drain |
Thu Nov 19 2020 6:40pm |
