Home > My Range Rover Sport > Power steering problem
Dylan
England 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi I have a 2010 rrs tdv6 and the power steering is ok one minute then it goes tight and notchy then back to light again . Have checked fluid level and belt tightness and both ok has anyone got an idea what to look for
Post #589276 Sat Oct 26 2019 2:08pm
Dave B
Not sure if this is relevant for your car, but similar issues on my truck and the cure was lubricating the lower steering coloum universal joint, initially with WD40, then when it was deemed to be the 'problem' heavier lubricating oil.
Post #589281 Sat Oct 26 2019 3:15pm
Dylan
Thank you for your reply I will check that to see if it is getting tight
Post #589282 Sat Oct 26 2019 3:44pm
Dylan
Hi Dave B I had a look at the bottom uj joint on the column this morning and it looked a bit dry so sprayed with wd40 and it has helped a great deal so I will take it off and give it a good bit of lube
Thanks again for your help
Tony
Post #589376 Mon Oct 28 2019 3:07pm
Dave B
You're welcome.
Some might suggest putting a smear of grease on it, but grease will just attract dust and dirt, so my advice is don't.
Glad to have been some help.
Dave
Post #589383 Mon Oct 28 2019 5:49pm
