Home > My Range Rover Sport > Power steering problem |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
Not sure if this is relevant for your car, but similar issues on my truck and the cure was lubricating the lower steering coloum universal joint, initially with WD40, then when it was deemed to be the 'problem' heavier lubricating oil. |
Sat Oct 26 2019 2:15pm |
Dylan Member Since: 14 Jun 2018 Location: Herts Posts: 13 |
Thank you for your reply I will check that to see if it is getting tight |
Sat Oct 26 2019 2:44pm |
Hi Dave B I had a look at the bottom uj joint on the column this morning and it looked a bit dry so sprayed with wd40 and it has helped a great deal so I will take it off and give it a good bit of lube
Mon Oct 28 2019 2:07pm |
You're welcome.
Mon Oct 28 2019 4:49pm |
