Home > Wheels & Tyres > L494 wheels on a L 320 problems
Page 1 of 3 123>
MEC
United Kingdom 2007 Range Rover Sport TDV6 HSE Sumatra Black
Hi all have picked up a set of brand new L494 wheels and tyres and fitted to my L320 thay look great but are triggering the abs on traffic islands thay are 255/55/r20 the ones I took off were 275/40r20 any now what I can do to solve the problem many thanks
Post #589174 Thu Oct 24 2019 4:48pm
knwatkins
What do you mean on traffic islands?
I have this size on my L320 with no problems. I assume you have replaced all four? Do they all have the same tyres with similar tread depth? Kev
Post #589176 Thu Oct 24 2019 5:31pm
ilard
On my L320 I have 275/40 from new. 255/55 are not the correct size for a 20 inch wheel are they? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #589179 Thu Oct 24 2019 6:01pm
Aren't 255/55 tyres the L494 size on 20s so the tyres are correct for the wheel as I understand it.
Does the OP mean the traction control is triggering when he says ABS? Or is it the ABS kicking in early when braking for junctions? Not sure I understand from his post. 2012 SDV6 - it's missing a couple of cylinders
Post #589180 Thu Oct 24 2019 6:09pm
knwatkins
Same here. I assume he talking about traction control and I'm leaning towards different tyres and/or tread wear which is resulting in the system kicking in. This has nothing to do with the particular profile of the tyre he is running as we know it happens on the standard 275/40/20 tyres also.
The above is just an assumption. Kev
Post #589181 Thu Oct 24 2019 6:26pm
MEC
Hi all sorry no to have been more clear the light on the dash is for the dsc it feels like the passenger side break is coming on the wheels are 20 inch original landrover whith 255/55r20 pirelli scorpion on all brand new thay have a larger rolling circumference which I assume is causing the problem but don't understand why when it appears other people are using them car drives fine on its original 20 inch wheels with 275 40 R20 on but they are on the last legs and these new wheels would have been a great upgrade any thoughts by traffic Islands I mean roundabouts many thanks all
Post #589183 Thu Oct 24 2019 6:50pm
knwatkins
As long as the rolling radius is equal on all four corners, is shouldn't make any difference. It certainly is a weird one.
Do you have access to another wheel of the same size? If so, you could try swapping one corner at a time to see if one corner is causing an issue. Kev
Post #589184 Thu Oct 24 2019 7:09pm
MEC
No only my original wheels wish I had now put back on but would really like to solve this problem and use new ones
Post #589185 Thu Oct 24 2019 7:19pm
Autobiography1969
Firstly the wheels will be fine as long as they are correctly load rated,,
Then 255/55/20's
Check the following;
Tyre pressure is the same on all 4
Tread depth is the same across the face on all 4
Condition of the side walls (No cracking at all)
If all of this is OK then I guess you may have just stepped outside of the
manufacturers design size..
L320 RRS is 275/40 or 45 many people use both profiles and no issues
As you said yourself the rolling radius is quite different..
Get a cheap ish set of 275/45/20 tyres and see if you get the same error with them..
worst case you have two sets of tyres and one of them will be up for sale..
https://tiresize.com/comparison/ ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #589187 Thu Oct 24 2019 7:39pm
Be worth checking the ABS sensors and their wires. Maybe one has been dislodged when the wheels were changed. 2012 SDV6 - it's missing a couple of cylinders
Post #589189 Thu Oct 24 2019 8:16pm
riverblanche
Hi,
only thing I can think to add is check the Width of the wheels Question
275 have an optimum width and so will 255 but if its a wide wheel it could be too wide for the 255 just a thought as said already it should cope with just the 30mm ish radius increase if all 4 are matched
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #589190 Thu Oct 24 2019 8:19pm
Duc750
you may of course have a lead foot - the nearside is the side that loads up most when going through a roundabout (Island in the midlands)
YOu should be able to get the CCF updated for the tyre size but really that should make naff all difference 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #589192 Thu Oct 24 2019 8:32pm
MEC
Hi all firstly what is CCF update as mentioned in last post secondly new wheels that I would like to keep 8 and a half J old ones are nine and a half J could I fit a tyre on new wheels that would give me same rolling radius as old ones new wheels are in 1/2 J 20 inch old ones are 9 and 1/2 J20 in Old tyres 275 40 R20 and drive fine but are really shabby new wheels are are perfect never dreamt this would be such a complicated issue
Post #589194 Thu Oct 24 2019 8:50pm
Duc750
Car Config File but I'd be pretty certain the problem is nothing to do with your wheels and tyres.
Right foot or a mechanical issue. 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #589199 Thu Oct 24 2019 10:02pm
MEC
Def not right foot only on a test run and going real slow if mechanical why is it ok whith original wheels on really confusing does the car config file effect dynamic stability control if I fit tyres that are 255/45/r20 that would be almost same rolling circumference as the original275/40r20 do you think that would work many thanks all
Post #589200 Thu Oct 24 2019 10:18pm
Page 1 of 3 123>
