![]() | Home > Wheels & Tyres > L494 wheels on a L 320 problems |
MEC Member Since: 19 Sep 2019 Location: Birminbham Posts: 15 ![]() ![]() ![]() |
Yes have put old wheels back on car drives perfect so definitely seems to be related two new wheels having a larger rolling circumference just can't figure out why why when all for match do you have a wheel bearing on driver's side that has a little bit of playing it which is next on the list don't think that would affect it as it's it's fine with the old wheels on |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Hi did you have them balanced? or has one wheel got a buckle in it? I have put 22" wheels on while my 20" get refurbed no problem, or it may just be slightly thinner wheel and even whilst driving normal it just maybe doing its job as the roads atm are more often damp than not. |
Only will be perfect brand new less than 200 miles on them wondering is it possible I may have and overactive sensor maybe but if so which one |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Right - its an 8% increase in tyre size so that really should make zero difference your best bet is to get it plugged in and try to capture some live data.
Yes old wheels and tyres are back on and new ones fitted perfect they are genuine Land Rover wheels and tyres so at a bit of a loss thanks for your reply |
Is the offset the same between both wheels. If the offset on the new wheels is more +ve then you may be catching sensor wires or something. Problem is without some live data readings this could be impossible to trace.
L494 20" wheels have an offset of et47. L320 20" wheels have an offset of et53.
Not that then. It's all guess work without codes and live data. 2012 SDV6 HSE (technically its hers)
I don’t think the off set will make any difference as I’m running 45 off set with 30mm spacers so 32mm in total,I can’t think of what the problem is,if he is running all 4 same side it shouldn’t affect the TC.Ive also had these same wheels fitted to my12 red edition with no problems. Andy. 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino |
Hi guys thanks for all all the head scratching it really is a problem could one of you explain what triggers dynamic stability control what sensors coming in to play could it be something to do with the height the cars sitting at or a steering angle sensor the only thing I can think of that's different with the new wheels is they are slightly taller and slightly narrower just driving the car 70 miles with old wheels and tires on no problems at all with the new ones did less than a mile car was undrivable thanks guys |
Can you get the VIN of the vehicle those wheels came off?
Will do but not till sunday thanks for your help |
I agree. It would make no difference. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Old wheels on no problem new wheels on problems, get the new ones checked just because they are new doesn't mean there might not have an issue causing your problems. |
