Home > Wheels & Tyres > L494 wheels on a L 320 problems |
MEC Member Since: 19 Sep 2019 Location: Birminbham Posts: 15 |
Hi all have picked up a set of brand new L494 wheels and tyres and fitted to my L320 thay look great but are triggering the abs on traffic islands thay are 255/55/r20 the ones I took off were 275/40r20 any now what I can do to solve the problem many thanks |
Thu Oct 24 2019 3:48pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
On my L320 I have 275/40 from new. 255/55 are not the correct size for a 20 inch wheel are they? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Thu Oct 24 2019 5:01pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
Aren't 255/55 tyres the L494 size on 20s so the tyres are correct for the wheel as I understand it.
Thu Oct 24 2019 5:09pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Same here. I assume he talking about traction control and I'm leaning towards different tyres and/or tread wear which is resulting in the system kicking in. This has nothing to do with the particular profile of the tyre he is running as we know it happens on the standard 275/40/20 tyres also.
Thu Oct 24 2019 5:26pm |
Hi all sorry no to have been more clear the light on the dash is for the dsc it feels like the passenger side break is coming on the wheels are 20 inch original landrover whith 255/55r20 pirelli scorpion on all brand new thay have a larger rolling circumference which I assume is causing the problem but don't understand why when it appears other people are using them car drives fine on its original 20 inch wheels with 275 40 R20 on but they are on the last legs and these new wheels would have been a great upgrade any thoughts by traffic Islands I mean roundabouts many thanks all |
Thu Oct 24 2019 5:50pm |
As long as the rolling radius is equal on all four corners, is shouldn't make any difference. It certainly is a weird one.
Thu Oct 24 2019 6:09pm |
No only my original wheels wish I had now put back on but would really like to solve this problem and use new ones |
Thu Oct 24 2019 6:19pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 472 |
Firstly the wheels will be fine as long as they are correctly load rated,,
Thu Oct 24 2019 6:39pm |
Be worth checking the ABS sensors and their wires. Maybe one has been dislodged when the wheels were changed. 2012 SDV6 - it's missing a couple of cylinders
Thu Oct 24 2019 7:16pm |
Thu Oct 24 2019 7:19pm |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
you may of course have a lead foot - the nearside is the side that loads up most when going through a roundabout (Island in the midlands)
Thu Oct 24 2019 7:32pm |
Hi all firstly what is CCF update as mentioned in last post secondly new wheels that I would like to keep 8 and a half J old ones are nine and a half J could I fit a tyre on new wheels that would give me same rolling radius as old ones new wheels are in 1/2 J 20 inch old ones are 9 and 1/2 J20 in Old tyres 275 40 R20 and drive fine but are really shabby new wheels are are perfect never dreamt this would be such a complicated issue |
Thu Oct 24 2019 7:50pm |
Car Config File but I'd be pretty certain the problem is nothing to do with your wheels and tyres.
Thu Oct 24 2019 9:02pm |
Def not right foot only on a test run and going real slow if mechanical why is it ok whith original wheels on really confusing does the car config file effect dynamic stability control if I fit tyres that are 255/45/r20 that would be almost same rolling circumference as the original275/40r20 do you think that would work many thanks all |
Thu Oct 24 2019 9:18pm |
