Home > Technical > 2.7 tdv6, no compression on cylinder 1: inlet valve stuck |
Flexzor Member Since: 29 Dec 2018 Location: Bruges Posts: 18 |
Hi!
Sat Jan 19 2019 7:28pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4986 |
Humm. Could be. I guess you need to remove 1 cam and see |
Sat Jan 19 2019 7:47pm |
Thanks for your prompt reply,
Sat Jan 19 2019 7:54pm |
Removed valve cover, turns out to be a broken valve spring in the inlet side.
Sat Jan 26 2019 11:59am |
interesting
Sat Jan 26 2019 12:40pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 908 |
Fit a new valve or you may be revisiting it soon. If the piston is not parallel to the valve face, chances are the valve spindle may be bent. It may be just slightly bent but will quickly wear the valve guide or a hairline crack in valve seat. Not worth doing the job twice. You may not be so lucky the second time. |
Sat Jan 26 2019 4:14pm |
Thanks for your replies guys.
Sat Jan 26 2019 6:06pm |
To remove the exhaust you go in thru the wheel arch.
Sat Jan 26 2019 6:32pm |
Thanks, clear instructions
Sat Jan 26 2019 8:46pm |
Can say on.
Sat Jan 26 2019 9:30pm |
The chain has 2 ? Dark red links to help with alignment on refitting.
Sat Jan 26 2019 9:50pm |
Sat Feb 02 2019 9:39am |
Sat Feb 02 2019 9:40am |
Any idea about the torque settings for the camshaft caps? Don’t see to find them.. |
Sat Feb 02 2019 10:06am |
