Home > Technical > 2.7 tdv6, no compression on cylinder 1: inlet valve stuck
Flexzor
Belgium 2009 Range Rover Sport TDV6 HSE Java Black
Hi!
After having 2 full fat RR's (1x 3.0 td6, 1x 4.2 Supercharged), I missed the Landrover "vibe" and bought a non-running 2.7 tdv6, 2009 with 200k km's, very tidy and with complete maintenance history, first owner....
Vague diagnosis from the Landrover dealer: rough running... Owners bought a new one..
After some analysis & removing things, I'm coming to the following:
- upgraded oil pump by last cam belt service
- cam belt in perfect condition, only 30000kms old
- running, but very rough, not al 6 cylinders and engine stalling very often (vehicle has DPF so no smoke visible...)
- No oil in turbo tubes
- I hear turbo spool up, so turbo not blocked
- removed injectors, will let them be tested
- 0.0 compression on cylinder 1, rest is ok: 17-18bar
- When pressurizing cylinder 1, I hear the air flowing out of the inlet main valve...
Can it be that an inlet valve is stuck open, but the pistons are not touching it? Can a broken valve spring be the cause?
Any thoughts?
thanks
Post #573460 Sat Jan 19 2019 8:28pm
Humm. Could be. I guess you need to remove 1 cam and see
Post #573462 Sat Jan 19 2019 8:47pm
Flexzor
Thanks for your prompt reply,
If the valve is opened a bit, for whatever reason, is it not directly touching the piston when cranking /running?
I don't know, for the 2.7 engine, how close the piston is to the valves, at TDC.
Post #573463 Sat Jan 19 2019 8:54pm
If the cambelt goes, the values do get bent.
So yes they are close.
But if the spring were to be broke, I guess the piston could push the valve back closed. (likely with some damage)
Post #573493 Sun Jan 20 2019 11:53am
Flexzor
Removed valve cover, turns out to be a broken valve spring in the inlet side.
I see a smooth, even marking on the piston: probably the piston pushing the valve back in.
Are the valves under 90 angle against the contacting surface of the piston? (it looks like it...)
Now will need to remove cams and try to replace spring without lifting the head... Any tips & tricks?
Post #573845 Sat Jan 26 2019 12:59pm
interesting
how do you see the piston ?
SO I guess you should rotate the engine, so that the piston is pushing on the valve to hold it in place.
I think this is near TDC
To remove the inlet cam, I think you need to remove the cambelt, which means to need to remove the fan (fan's are difficult to remove on these, get some tools)
You can get cheap timing alignment tools for these off ebay.
Starter requires removal to use.
I can't help think for the sake of removing the EGR/exhaust manifold and head it maybe best to fit a new valve?
But I guess you can test the seal after a new spring is fitted ? or maybe test the seal while the piston holds the valve up?
Post #573848 Sat Jan 26 2019 1:40pm
Lindab
Fit a new valve or you may be revisiting it soon. If the piston is not parallel to the valve face, chances are the valve spindle may be bent. It may be just slightly bent but will quickly wear the valve guide or a hairline crack in valve seat. Not worth doing the job twice. You may not be so lucky the second time.
Post #573856 Sat Jan 26 2019 5:14pm
Flexzor
Thanks for your replies guys.
I bought a small 5.5mm camera to fit in the injector hole. This way i'm able to look in the cylinder.
FYI: i bought a compression tool kit with a dummy injector to test compression without the need to remove the glowplugs...
I think i will go for the head removal.
As my body is still on, will i be able to losen the exhaust manifold easy?
Are there other things that i need to remove? This side (UK driver side) is the easy one, right? There is no belt for the HP fuel pump on this side. However, i see another "Bosch" part attached to the rear of the head. Any idea what this can be?
Post #573872 Sat Jan 26 2019 7:06pm
To remove the exhaust you go in thru the wheel arch.
Remove the many bits of Heatshield in the arch.
Take your time to mark how the heat shields fit together. It will save much time later.
Remove EGR and EGR shield. A 1/4 drive 8mm socket and long extension 40cm? from memeory is your friend here.
UNBOLT exhaust.
The thing on the back is the brake vacuum pump.
Not a big deal except the seal is expensive
Head gasket thickness are selected in manufacture.
The notches at the front indicate thickness.
On the side of the block at front is a coolant drain plug. I recommend you unscrew before head removal otherwise you will get coolant in the oil
If your glowplugs don’t work on that side would be a good time to replace when head off
Post #573875 Sat Jan 26 2019 7:32pm
Flexzor
Thanks, clear instructions
Do you know if the brake vacuum pump stays on the head or needs to be removed before head is taken off?
Post #573892 Sat Jan 26 2019 9:46pm
Can say on.
There are 2 or 3 bolts that hold the transmission breather pipes to the head. These need removing. They are next to the vacuum pump. Bit of a pain.
The head has 2 dowels.
So the head needs lifting up and then into the center of Vee
Post #573897 Sat Jan 26 2019 10:30pm
The chain has 2 ? Dark red links to help with alignment on refitting.
The factory don’t always bother to make use of them.
Post #573901 Sat Jan 26 2019 10:50pm
Flexzor
Photo says enough..
Post #574287 Sat Feb 02 2019 10:39am
Post #574288 Sat Feb 02 2019 10:40am
Flexzor
Any idea about the torque settings for the camshaft caps? Don’t see to find them..
Post #574295 Sat Feb 02 2019 11:06am
