Home > My Range Rover Sport > tailgate |
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 |
Anybody know if there's away to open the tailgate on my 2012 rrs when there's no power supply |
Thu Jul 26 2018 2:18am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4986 |
Is it the one piece powered tailgate? as I assume you have checked Fuse No. 15 in engine bay fuse box.
Thu Jul 26 2018 4:55am |
yes one piece, sorry I should said I have the body off at the moment, and I need to open it |
Thu Jul 26 2018 5:34am |
Deleted
Thu Jul 26 2018 6:49am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
Have you tried unlocking on the fob and manually lifting? 2019 5.0 SC SVA (Current)
Thu Jul 04 2019 11:08am |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 |
Yes I can open the tailgate manually but not powered. RRS (MY13) Santorini Black SDV6 HSE luxuary
Thu Jul 04 2019 11:24am |
Probably a strut fail but check the fuse to be sure. Can’t remember which it is (check Cols post above) but it’s called power tail gate so should be easy to spot. 2019 5.0 SC SVA (Current)
Thu Jul 04 2019 1:54pm |
Thanks for your suggestion but what is a strut fail? RRS (MY13) Santorini Black SDV6 HSE luxuary
Thu Jul 04 2019 4:22pm |
It might be very relevant that the tailgate open/close failure under power happened when I disconnected the battery to sort out my glowplug warning light issue.
Thu Jul 04 2019 4:36pm |
The 2 struts are the powered parts that lift the tail. Did you check the fuse? 2019 5.0 SC SVA (Current)
Thu Jul 04 2019 5:05pm |
Just noticed you say powered opening and closing. The original only power closed from the button, is that what you mean or has it got aftermarket kit fitted which allows closure off the fob? 2019 5.0 SC SVA (Current)
Thu Jul 04 2019 5:08pm |
Yes it has aftermarket unit allowing for remote closing. RRS (MY13) Santorini Black SDV6 HSE luxuary
Thu Jul 04 2019 5:13pm |
Hi Brit Plumber, yes the fuse was missing. Now the tailgate works fine.
Thu Jul 04 2019 5:25pm |
Look in the fuse box for a system that you don’t have as the fuse box comes with all fuses fitted regardless of options. Things like RSE, cruise, fridge etc. That you may not have serve as emergency spares.
Thu Jul 04 2019 5:46pm |
