Home > My Range Rover Sport > tailgate
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
tailgate
Anybody know if there's away to open the tailgate on my 2012 rrs when there's no power supply Crying or Very sad
Post #562045 Thu Jul 26 2018 2:18am
Is it the one piece powered tailgate? as I assume you have checked Fuse No. 15 in engine bay fuse box.
Post #562046 Thu Jul 26 2018 4:55am
blueiceplus
tailgate
yes one piece, sorry I should said I have the body off at the moment, and I need to open it Rolling Eyes
Post #562047 Thu Jul 26 2018 5:34am
Deleted
Post #562050 Thu Jul 26 2018 6:49am
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
My one piece tailgate has stopped powered opening and closing.
The lock switch operates OK (can be heard clicking) but neither the dash or tailgate switches induce operation equally the key fob has no effect.
Any ideas welcome! RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #583502 Thu Jul 04 2019 12:59am
Brit Plumber
Have you tried unlocking on the fob and manually lifting? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583513 Thu Jul 04 2019 11:08am
LG8340
Yes I can open the tailgate manually but not powered. RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #583515 Thu Jul 04 2019 11:24am
Brit Plumber
Probably a strut fail but check the fuse to be sure. Can’t remember which it is (check Cols post above) but it’s called power tail gate so should be easy to spot. 2019 5.0 SC SVA (Current)
Post #583526 Thu Jul 04 2019 1:54pm
LG8340
Thanks for your suggestion but what is a strut fail? RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #583532 Thu Jul 04 2019 4:22pm
LG8340
It might be very relevant that the tailgate open/close failure under power happened when I disconnected the battery to sort out my glowplug warning light issue.
I’ve read somewhere that a hard reset might sort it but can someone help and tell me how to do a hard reset. RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #583533 Thu Jul 04 2019 4:36pm
Brit Plumber
The 2 struts are the powered parts that lift the tail. Did you check the fuse? 2019 5.0 SC SVA (Current)
Post #583534 Thu Jul 04 2019 5:05pm
Brit Plumber
Just noticed you say powered opening and closing. The original only power closed from the button, is that what you mean or has it got aftermarket kit fitted which allows closure off the fob? 2019 5.0 SC SVA (Current)
Post #583535 Thu Jul 04 2019 5:08pm
LG8340
Yes it has aftermarket unit allowing for remote closing. RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #583536 Thu Jul 04 2019 5:13pm
LG8340
Hi Brit Plumber, yes the fuse was missing. Now the tailgate works fine.
Must have happened when I did the ECU reset to fix the glow plug warning light issue. I probably popped a fuse that I tested back in the wrong slot.
Problem is that now I’m short of a 15A fuse. Seems JLR are too mean to provide any spares!
Many thanks! RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #583537 Thu Jul 04 2019 5:25pm
Brit Plumber
Look in the fuse box for a system that you don’t have as the fuse box comes with all fuses fitted regardless of options. Things like RSE, cruise, fridge etc. That you may not have serve as emergency spares.
At least the fix isn’t a pair of new struts lol👍 2019 5.0 SC SVA (Current)
Post #583540 Thu Jul 04 2019 5:46pm
