Home > General > Wishbone replace or not ??
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
Hi , I've had my 2008 tdv8 for 2 years now with 95000 on the clock and I'm wondering if its time to have the lower wishbones replaced , I've noticed that over rough ground a sort of knocking noise is noticeable but generally on normal road surface the car is fine with no real issues with steering . I understand from reading the post on this issue that most rrs would need this work done by the time they reach 70000 miles so I guess mine would benefit from having it done , just been quoted £795 , that's both sides and 4 wheel alignment incl vat from local Indy . Also they quoted £700 just for complete track rods which seemed a little expensive ?? Thou I don't imagine I would need complete track rods just the track rod ends on each side ( thought I'd get the quote for that probably overkill ) what's your thoughts please , cheers
Post #517361 Fri Feb 10 2017 6:43pm
Phatcat
2005 Range Rover Sport TDV6 SE Zermatt Silver
Check your ARB bushes Series 3 gone
90 gone
Freelander v6 gone ( thirsty pig )
Defender gone
Ktm 1290 SA (gone)
BMW 1200 GSA
Post #517366 Fri Feb 10 2017 8:04pm
Re: Wishbone replace or not ??
A complete track rod with both ends is about £40 a side. So £80 for the front axle. Fitting isn't going to be several hours. The rear rods are about £60-70 each for OEM so £120-140 for the rear axle. Again, fitting isn't several hours. An alignment would be needed, obviously, but should be less than £100 if it's not at a LR dealership. I would think that £700 would be top end for the job.
As for whether your lower arms need changing, that depends on what the vehicle has been doing. 90k miles on the motorway is probably ok. 95k miles thumping around potholed roads and off road and they're probably well past their best. £795 for both arms plus alignment and the VAT sounds reasonable although, no doubt, someone will be along soon to say it's expensive! Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #517370 Fri Feb 10 2017 9:34pm
Disco_Mikey
It is expensive Thumbs Up
Post #517373 Fri Feb 10 2017 10:51pm
Alfie
Can anyone recommend an independent 4x4 garage in Lincolnshire as I live just 20 miles north of Peterborough , thanks
Post #517383 Sat Feb 11 2017 7:42am
Alfie
Just gone over the quote again and I quote " steering rack track and track rod ends £709.43 " which is way more than I expected , I doubt that a complete steering rack track would be needed , and I will ask them to quote for just new track rod ends
Post #517384 Sat Feb 11 2017 7:54am
riverblanche
Hi,
all sounds a bit confusing so I would be asking for the Exact details of what is required to be confirmed Question
then have a word with Famous Four at Louth if you want an indp for advice/cost
Post #517675 Mon Feb 13 2017 5:12pm
Alfie
Ok thanks for the Indy info , just had a quote from my Indy 4x4 and they have quoted £260 just to replace track rod ends !!! I think the quote for the wishbones was a fair price at £795 but some jobs they quote seem way more than I would expect 😯 I just contacted my local stealers for price on parts only ( wishbones) and think I will do the job myself later this year
Post #517683 Mon Feb 13 2017 6:45pm
