Home > General > Wishbone replace or not ?? |
Phatcat Member Since: 27 Dec 2015 Location: Wetherby Posts: 12 |
Check your ARB bushes Series 3 gone
Fri Feb 10 2017 8:04pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
A complete track rod with both ends is about £40 a side. So £80 for the front axle. Fitting isn't going to be several hours. The rear rods are about £60-70 each for OEM so £120-140 for the rear axle. Again, fitting isn't several hours. An alignment would be needed, obviously, but should be less than £100 if it's not at a LR dealership. I would think that £700 would be top end for the job. As for whether your lower arms need changing, that depends on what the vehicle has been doing. 90k miles on the motorway is probably ok. 95k miles thumping around potholed roads and off road and they're probably well past their best. £795 for both arms plus alignment and the VAT sounds reasonable although, no doubt, someone will be along soon to say it's expensive! 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Feb 10 2017 9:34pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
It is expensive |
Fri Feb 10 2017 10:51pm |
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 |
Can anyone recommend an independent 4x4 garage in Lincolnshire as I live just 20 miles north of Peterborough , thanks |
Sat Feb 11 2017 7:42am |
Just gone over the quote again and I quote " steering rack track and track rod ends £709.43 " which is way more than I expected , I doubt that a complete steering rack track would be needed , and I will ask them to quote for just new track rod ends |
Sat Feb 11 2017 7:54am |
Mon Feb 13 2017 5:12pm |
Ok thanks for the Indy info , just had a quote from my Indy 4x4 and they have quoted £260 just to replace track rod ends !!! I think the quote for the wishbones was a fair price at £795 but some jobs they quote seem way more than I would expect 😯 I just contacted my local stealers for price on parts only ( wishbones) and think I will do the job myself later this year |
Mon Feb 13 2017 6:45pm |
