![]() | Home > Technical > Range rover sport 2.7 tdv6 noise on starting |
For a second or 2, until the oil pressure warning goes out? |
Timing belt on a 2.7
Pxcars Member Since: 17 Dec 2016 Location: Trefeglwys Posts: 13 ![]() ![]() ![]() |
Yes for few second until get oil pressure, is the timing chain oil pressure tensioned or spring tensioned thanks David |
Oil light out straight away probably last few seconds after oil light out have changed oil every 6k miles using genuine filter |
Yes aware it is timing belt but also has timing chains to sync the camshafts |
That's normal. All 2.7's do it The chains are spring loaded, and oil damped ![]() |
Could be dry cam followers/tappets on the camshaft, basically waiting for the oil pressure to build up.
Flexzor Member Since: 29 Dec 2018 Location: Bruges Posts: 18 ![]() ![]() ![]() |
Sorry for reviving this old topic: is this a common item on the 2.7 engine what disco mickey mentions? |
Topsy Member Since: 06 Jan 2017 Location: Swansea Posts: 48 ![]() ![]() ![]() |
Hi
