Home > Technical > Range rover sport 2.7 tdv6 noise on starting |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
For a second or 2, until the oil pressure warning goes out? |
Sat Feb 04 2017 9:46am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Timing belt on a 2.7
Sat Feb 04 2017 9:49am |
Pxcars Member Since: 17 Dec 2016 Location: Trefeglwys Posts: 13 |
Yes for few second until get oil pressure, is the timing chain oil pressure tensioned or spring tensioned thanks David |
Sat Feb 04 2017 9:53am |
Oil light out straight away probably last few seconds after oil light out have changed oil every 6k miles using genuine filter |
Sat Feb 04 2017 9:57am |
Yes aware it is timing belt but also has timing chains to sync the camshafts |
Sat Feb 04 2017 10:02am |
That's normal. All 2.7's do it The chains are spring loaded, and oil damped |
Sat Feb 04 2017 10:18am |
Could be dry cam followers/tappets on the camshaft, basically waiting for the oil pressure to build up.
Sat Feb 04 2017 10:19am |
Flexzor Member Since: 29 Dec 2018 Location: Bruges Posts: 18 |
Sorry for reviving this old topic: is this a common item on the 2.7 engine what disco mickey mentions? |
Sun Feb 24 2019 7:46pm |
Topsy Member Since: 06 Jan 2017 Location: Swansea Posts: 48 |
Hi
Mon Feb 25 2019 11:24am |
