Home > Technical > Range rover sport 2.7 tdv6 noise on starting
Pxcars
United Kingdom 2006 Range Rover Sport TDV6 HSE Santorini Black
Hi all looking for some more advice regarding my rrs. Its a bit of a strange one really every time I start from cold I get a slight top end rattle from the right bank and was wondering if anyone has had similar. I'm thinking it's timing chain rattle or soft lifter? Any advice would be great as I'm going to pull it apart! Oh it's a tdv6 2.7 done 78k
Post #516719 Sat Feb 04 2017 10:39am
Disco_Mikey
For a second or 2, until the oil pressure warning goes out?
Post #516720 Sat Feb 04 2017 10:46am
SRE
Spain
Timing belt on a 2.7
A little more info might help
Does your oil warning light extinguish straight away when you start the car?
How long does the rattle last?
What have you done to the car recently, e.g. Has it had a recent oil and filter change? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #516722 Sat Feb 04 2017 10:49am
Pxcars
Yes for few second until get oil pressure, is the timing chain oil pressure tensioned or spring tensioned thanks David
Post #516723 Sat Feb 04 2017 10:53am
Pxcars
Oil light out straight away probably last few seconds after oil light out have changed oil every 6k miles using genuine filter
Post #516724 Sat Feb 04 2017 10:57am
Pxcars
Yes aware it is timing belt but also has timing chains to sync the camshafts
Post #516725 Sat Feb 04 2017 11:02am
Disco_Mikey
That's normal. All 2.7's do it
The chains are spring loaded, and oil damped Thumbs Up
Post #516727 Sat Feb 04 2017 11:18am
SRE
Spain
Could be dry cam followers/tappets on the camshaft, basically waiting for the oil pressure to build up.
Worth checking the HPFP belt on the rear of the engine.
EGR valve starting to play up.
What year is the car In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #516728 Sat Feb 04 2017 11:19am
Flexzor
Belgium 2009 Range Rover Sport TDV6 HSE Java Black
Sorry for reviving this old topic: is this a common item on the 2.7 engine what disco mickey mentions?
Post #575822 Sun Feb 24 2019 8:46pm
Topsy
Wales 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
It's difficult to be sure without hearing that actual car but; I had mine for 7 years and there was always a slight rattle on start -up. Over in an instant and fine from there on.
Post #575860 Mon Feb 25 2019 12:24pm
