Home > In Car Electronics > What dash cam
Page 1 of 3 123>
ShooterNeil
What dash cam
Think it's time for a dash cam
After having someone pull out on me and now my car is in body shop and I am driving a c1 😡😡😡😡😡
The other driver said I run a red light funny how no other cars at the junction pulled off the same time as he did not even till we had moved to a safer spot as there lights were on RED
so what dash cams are good for around 100 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #507348 Sat Oct 08 2016 3:40pm
Buckster
I believe the next base is good for within your 100 budget you have set.
I personally use a ThinkWare X550 front and Rear and it's a great bit of kit. Even records while parked incase someone hits you Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #507351 Sat Oct 08 2016 4:49pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
I have a nextbase 402g installed, it's good but they all suffer from internal battery fail normally around 10 months, so then it's back to the seller to try claim for a repair under warranty, if your lucky it fails well with in 12 months. Mine died at 11 months so I had to buy my own internal battery (took a lot of googling to find the right one) and begin minor surgery replacing it.
This would be my next choice
http://www.argos.co.uk/static/Product/part...AmB-8P8HAQ
Can take a 64gb card where the nextbase is maxed at 32gb.
This guy is on another forum I frequent, I also subscribe to his you tube channel, but this definitely highlights the usefulness
Post #507378 Sun Oct 09 2016 7:14am
Tyrefitter
I've got the thinkware 770 & it's a good bit of kit with many useful features but they are 250.
Buckster,,I have the Thinkware 770 & was going to set it so it records when parked up but I'm worried about my battery going flat on the car as I have it hardwired.Have you connected yours to a battery pack.?
Also mine seems to take about 40 minutes driving before the gps connects,at first I thought it was where I had it mounted so I moved it & it's still the same.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #507380 Sun Oct 09 2016 7:36am
I have a Thinkware 770 hardwired in mine and have never had a battery issue, it is voltage sensed which you can set in the menu so it switches off if battery starts to get low. GPS connects within a minute or so but it is a RRS1 and not a solar whatever windscreen.
Post #507384 Sun Oct 09 2016 7:52am
Buckster
Andy.
What Col said, I have it hard wired and all ThinkWare have a voltage drop sensor that will switch it off if battery gets to low.
I do sometimes get the GPS connection straight away and other times it can take a while before it connects. I have a work colleague that has one and his does the same Rolling Eyes 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #507388 Sun Oct 09 2016 9:15am
Tyrefitter
Once mine as connected it will connect within seconds of turning ignition on unless it's been parked up over night then it takes longer.ill go into the settings & set it to park mode or whatever it is & set voltage,,what voltage have you guys set it to or will it be set to reccomended voltage.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #507395 Sun Oct 09 2016 10:29am
ShooterNeil
Thanks for the info cars been in body shop for 8 working days now for a wing and headlight and a bumper if it can't be welded 61 AB 5.0 supercharged rocket
Post #507421 Sun Oct 09 2016 3:22pm
Johnski
I think you should only be paying around £199.00 for the Thinkware F770 UK, not the £250 stated. I purchased one last week at the £199.00 Front & Rear HD. Whistle John
Post #507469 Mon Oct 10 2016 12:13am
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Just installed a Blackvue 650 front and rear in the wife's car - (should have been going into my car) and am extremely happy with it. A touch sensitive but great all round package 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #507472 Mon Oct 10 2016 5:36am
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Johnski wrote:
I think you should only be paying around 199.00 for the Thinkware F770 UK, not the 250 stated. I purchased one last week at the 199.00 Front & Rear HD. Whistle
Care to let us know where? Wink
Post #507515 Mon Oct 10 2016 2:43pm
other option is buy a F750, and do the firmware upgrade to the F770, as per flydrives thread a week or so ago
My F750 is loads more responsive now, with quicker connection to GPS and the time lapse parking is better
You just dont get a as neat look as the F770, but might be cheaper Idea
Post #507516 Mon Oct 10 2016 2:55pm
This is where mine came from. 199.00 for 16Gb 249.00 for 32GB both with Hardwire Kit.
http://thinkwaredashcam.uk/?gclid=CI7on6HYgs0CFawp0wodGPECJA
Post #507517 Mon Oct 10 2016 2:55pm
Paulcp
Thanks Col, I looked there and the 770 with F & R cameras was 249, front only @199.
I was just wondering where the 770 F&R is available @199 as per Johnski's post
@npinks, yes, the 750 & upgrade is certainly an option, will look into that. Just started the search for a new dashcam since my 3 year old blackvue seems to be on its way out!
Post #507525 Mon Oct 10 2016 3:57pm
Tyrefitter
The F&r are available from thinkware at 199 but with the 16gb instead of the 32.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #507530 Mon Oct 10 2016 6:54pm
Page 1 of 3 123>
