![]() | Home > Maintenance & Modifications > osr door wont open |
Sounds as if there is a problem with the small motor that operates the deadlock. How is the voltage on your battery? I saw your other post about intermittent loss of the rear camera and wondered if it might be related to low volts.
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 ![]() ![]() ![]() |
I thought I would post an update on my door lock issue. I spoke with the guy from LR trade parts http://lrtradeparts.co.uk/ and explained the lock had failed 2 weeks in after fitting. Apparently when they do fail they can get jammed and the only way is to brute force destruction to get them removed
Anyhow having the old lock still at to hand I studied the mechanism and there is a cam arm inside the lock that could maybe manually activated/picked which could free the lock mechanism. Any idea was worth a shot before brute force and trashing the lock so figured to give it ago. ![]() I took some photos of the old lock I removed that was playing up. Added some arrows on the pics to show what and where to start "picking"
![]() To get access to this you need to break off a small piece of the plastic that covers the end of the mechanism. The whole procedure is a little tricky as you need to go blind and feel the lock in the door panel. And trying this blind is testing ![]() Trick is to find a right angle tool that you can get in and try to lift the cam. There is not much room as its quite tight against the side of outer door skin. A bit of searching the tool case and best tool for the job was 5mm allen key. This seemed to fit perfectly and allowed me to lift the cam upwards. ![]() Bingo ![]() Door swings open and access to the lock for removal,
Removal of the lock it appears the electrical side has jammed the lock in a "Locked" state. So the cam that contacts the outer door handle was not contacting. The inside door handle was also rendered inoperable (obviously) This isn't going to work in every scenario but if it helps someone else then that's great after all the great advice I have gleaned from here. ![]() adam. |
NeilRRS Member Since: 18 Aug 2016 Location: Stone, Staffs. Posts: 36 ![]() ![]() |
Old post but still useful as my new lock also locked me out and I had to conduct the above to get in again... |
Adrian C Member Since: 07 Nov 2024 Location: Hampshire Posts: 1 ![]() ![]() |
This is brilliant advice, and just what I have been looking for. Every other bit of advice has been to press the lock/unlock buttons repeatedly and hope for the best. I've just bought a 2007 RRS and the lock has never worked or even made the slightest of noises. I was fearing that I would have to damage my RRS in some way just to get the door to open and then have to live with the battle scares forever more!!! So fingers crossed this works for me tomorrow. |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
I never use superlock on my TDV8 just in case the door lock fails and I cannot open the car from the inside. I figure after 14 years one of the locks is about to bound to fail. |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
One easy fix that can outsmart even the smartest of operators, is the door pin that pops up in the door card to show whether the door is locked or not.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Don't recall the sport having the pop-up type button, is the button not part of the internal release handle assy. Have had one rear door lock/actuator fail but was initially intermittent so changed it before it failed completely with the door locked.
Good point Col - my experience of this happening was on an L322. |
