Home > Maintenance & Modifications > osr door wont open |
Sounds as if there is a problem with the small motor that operates the deadlock. How is the voltage on your battery? I saw your other post about intermittent loss of the rear camera and wondered if it might be related to low volts.
Sat Oct 08 2016 5:30pm |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
I thought I would post an update on my door lock issue. I spoke with the guy from LR trade parts http://lrtradeparts.co.uk/ and explained the lock had failed 2 weeks in after fitting. Apparently when they do fail they can get jammed and the only way is to brute force destruction to get them removed . LR trade parts returns procedure is a carrier swap out, but explaining this was going to be difficult as I can only work on the car at weekends so would leave the car unlocked for a period until an exchange is arranged I was able to put a £20 deposit down on a second unit shipped and get a refund on the exchange on return. So LR Trade Parts for their help.
Mon Oct 17 2016 8:56pm |
nice to see a well thought out solution, Congratulations. 2008 MY Java Black TDV8 HSE
Tue Oct 18 2016 3:44pm |
NeilRRS Member Since: 18 Aug 2016 Location: Stone, Staffs. Posts: 36 |
Old post but still useful as my new lock also locked me out and I had to conduct the above to get in again... |
Thu Aug 31 2017 3:28pm |
Adrian C Member Since: 07 Nov 2024 Location: Hampshire Posts: 1 |
This is brilliant advice, and just what I have been looking for. Every other bit of advice has been to press the lock/unlock buttons repeatedly and hope for the best. I've just bought a 2007 RRS and the lock has never worked or even made the slightest of noises. I was fearing that I would have to damage my RRS in some way just to get the door to open and then have to live with the battle scares forever more!!! So fingers crossed this works for me tomorrow. |
Sun Nov 10 2024 1:22pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 |
I never use superlock on my TDV8 just in case the door lock fails and I cannot open the car from the inside. I figure after 14 years one of the locks is about to bound to fail. |
Sun Nov 10 2024 4:39pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 409 |
One easy fix that can outsmart even the smartest of operators, is the door pin that pops up in the door card to show whether the door is locked or not.
Sun Nov 10 2024 6:32pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5027 |
Don't recall the sport having the pop-up type button, is the button not part of the internal release handle assy. Have had one rear door lock/actuator fail but was initially intermittent so changed it before it failed completely with the door locked.
Sun Nov 10 2024 7:49pm |
Good point Col - my experience of this happening was on an L322. |
Sun Nov 10 2024 7:58pm |
