Home > In Car Electronics > USB charger install
tanloverluke
USB charger install
After several trips to london and having lost my charger that connects to the lighter, I now wonder if there is a way to connect a usb charger to the centre console? Looking at the centre console there are a couple of blanks where a usb module would fit. I have googled and found nothing for the range rover sport. I know that there is something [pre-historic Whistle ] in the fridge flap, yet I don't want to have to open this to have to get to a charger. Any help/suggestions much appreciated.
I have read about plugging in a usb adaptor to the lighter. this will work, however I was hoping for a more permanent solution that would leave the lighter slot free.
Thanks Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #504750 Wed Sep 07 2016 3:37pm
Not seen anything on here, or much on D3 forum, but you could fit something like this to the ciggy lighter socket? ON THE WAY: BMW F21 M140i
Post #504752 Wed Sep 07 2016 3:52pm
Guyzer73
Tanoverluke, I did something similar to what Beancounter said however installed it in te rear lighter socket to maintain flexibility at the front.
Post #504753 Wed Sep 07 2016 4:22pm
tanloverluke
Thanks chaps. That's an interesting twist Guy, I didn't realist that there was a lighter in the rear. The question beckons, do I want to drill a hole in one of the blanks by the heating control and install this adaptor, or plug in into the rear lighter.
Guy, the adaptor that you have, is it the same output for both USB ports, or it is similar to the one bean counter posted? My preference is for both of them to be the same output to charge a mobile device. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #504754 Wed Sep 07 2016 4:34pm
tanloverluke
Beancounter what's the difference between 1a and 2.1a? I am clueless hence if I stepped into a car and was faced with this charger I wouldnt know which port to use. Thanks. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #504755 Wed Sep 07 2016 4:38pm
Guyzer73
Tanloverluke,
1A and 2.1A refer to the Ampage of the USB charger. Both runUSB sockets will run at 5VDC. 2.1A is for tablets and I think Apple products.
I think mine runs up to 3.1A total but can be split 2.1A and 1A, some are rated higher at 2.1A and 2.1A each, so total 4.2A at 5VDC.
You can't install in the blanks by the heater controls or stereo as there are PCB (Printed Circuit Boards) behind the fascias. The only option up front are as BC said to replace the existing lighter socket. Alternatively you could mount it in a completely random position like on the side of the center console pointing into the 'foot well'of the passenger seat.
Hope that helps
Post #504756 Wed Sep 07 2016 4:46pm
Both will charge an iphone for example, but the 2.1 will do it quicker, also would be the one you'd use for iPad's etc, though they would usually draw even more.
I'm sure there are variants on this model which would supply higher A output, just need to do a bit of investigation. Thumbs Up ON THE WAY: BMW F21 M140i
Post #504757 Wed Sep 07 2016 4:46pm
This is what I did, fitted it in Glove box and connected to fuse box via a rocker switch so can switch in on and off as needed and phone can be left on charge out of site.
Post #504766 Wed Sep 07 2016 6:43pm
Gilly1
Hi, not sure if this will help in anyway but thought I'd add it for you. http://www.ebay.co.uk/itm/HitCar-Car-DC-12...1935055293 Thumbs Up
Post #504771 Wed Sep 07 2016 7:54pm
riverblanche
Hi,
there has been a recent thread on D3 fitting an "anker" 40w multi usb adaptor from memory onto the front 12v plug
Post #504786 Wed Sep 07 2016 9:47pm
tanloverluke
many thanks for the input! I'm currently looking for a usb adaptor that can be hard wired into the front of the car, however for the rear I'll go for the cigarette lighter route as suggested. I hope to post some pics along the way. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #504788 Wed Sep 07 2016 10:30pm
Guyzer73
Here are two options for you:
Fixed install:
https://powerwerx.com/panel-mount-dual-usb...igh-output
This gives 2x 5VDC 2.1A
Cigarette lighter (can be made permanent if you're handy):
https://www.amazon.com/SCOSCHE-USBC242M-Ch...B00E1UWA4O
This gives 2x 5VDC 2.4A
I'd go with the fixed install in the glove box like Col if I did it again.
Post #504789 Thu Sep 08 2016 4:36am
tanloverluke
Thanks chaps, much appreciated. I ordered a flush mounted USB charger from Powerful this morning:
http://www.powerfuluk.com/12v-usb-caravan-...l-usb.html
Should arrive early next week which will give me enough time to have it wired by the weekend. Just got to look for the soldering iron now Thumbs Up Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #504808 Thu Sep 08 2016 10:12am
Lyonhead
Wales
Hey Col, that looks a really nice job. Well done Thumbs Up Thumbs Up
Post #504812 Thu Sep 08 2016 10:23am
Agreed, tastefully done Bow down Thumbs Up ON THE WAY: BMW F21 M140i
Post #504825 Thu Sep 08 2016 11:27am
