Home > In Car Electronics > USB charger install |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
Hi Dennis the one that I've purchased is not for installation in the cigarette lighter, instead it's to be installed on a panel. If you read the Powerful description, it reads: "This is a stand alone flush mount Dual USB power supply socket...This design has a threaded rear "barrel" that is 33mm long so can be used to mount in any panel from 0 -30mm thick." Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Thu Sep 08 2016 10:50pm |
I did somthing simular but wanted it more accessable while driving so installed a charger+aux above the cooler box.
Fri Sep 09 2016 2:57pm |
MonteChristo Member Since: 16 May 2016 Location: CK Posts: 11 |
few examples:
Thu Sep 15 2016 11:45am |
Thanks to everyone that's helped along the way. I managed to install the charger today, arrived from PowerfulUK, and it's working perfectly. I decided to install it on the dash, by the sat nav screen. There is absolutely nowhere on the centre console where it will fit and I didn't want it in the glovebox because of the reach. Now that it's in place I am in fact extremely happy with the position, easy to access and it means I can still use Google Maps whilst driving.
Thu Sep 15 2016 9:52pm |
Referencing earlier posts on the charging amps for any type charger, a higher amp number doesn't mean a faster charge unless your phone/device can use it, or the voltage is outwith standard USB 5 volt spec as many larger devices now are. What the amp rating means is the potential amps available. So a phone which has a 1 amp charge draw will charge in exactly the same time on either of those usb outlets, or in your house charger if so rated. If a device has a 1.5 amp draw then it will be restricted to 1 amp charge on the 1 amp outlet, but full 1.5 amp on the 2.1 amp outlet. But no harm will be done using the 1 amp outlet, just a slower charge - this can be useful with modern lithium batteries as it can apparently shorten their life when charging to 100% - daft, but supposed to be true (I've changed my charge habits completely after reading tests on this). Then a large tablet etc. with bigger amp draw would be recommended to use the 2.1 amp outlet but probably manage on the 1 amp fine just slower. I have found my tablet didn't like it on a 0.5 amp charger as it must've been too low, or was possibly poor quality.
Thu Sep 15 2016 10:56pm |
Thanks for the info insiorc, that certainly is food for thought.
Fri Sep 16 2016 7:22am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
In my pic the cigarette lighter is removed and the hole slightly enlarged to accept a force fit 'standard' cigarette lighter USB charger. But looking at the hard wire option from tanloverluke I might get a couple and replace the existing USB and cigarette lighters...
Fri Sep 16 2016 7:40am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4973 |
Do you not have the Usb socket under the Flap in the panel between the Front Seats? although you would nearly need to be double jointed to reach it from front seats.
Cheers Col |
Fri Sep 16 2016 8:03am |
