Home > In Car Electronics > USB charger install |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
After several trips to london and having lost my charger that connects to the lighter, I now wonder if there is a way to connect a usb charger to the centre console? Looking at the centre console there are a couple of blanks where a usb module would fit. I have googled and found nothing for the range rover sport. I know that there is something [pre-historic ] in the fridge flap, yet I don't want to have to open this to have to get to a charger. Any help/suggestions much appreciated.
Wed Sep 07 2016 3:37pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Not seen anything on here, or much on D3 forum, but you could fit something like this to the ciggy lighter socket? ON THE WAY: BMW F21 M140i
Wed Sep 07 2016 3:52pm |
Thanks chaps. That's an interesting twist Guy, I didn't realist that there was a lighter in the rear. The question beckons, do I want to drill a hole in one of the blanks by the heating control and install this adaptor, or plug in into the rear lighter.
Wed Sep 07 2016 4:34pm |
Beancounter what's the difference between 1a and 2.1a? I am clueless hence if I stepped into a car and was faced with this charger I wouldnt know which port to use. Thanks. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Wed Sep 07 2016 4:38pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Tanloverluke,
Wed Sep 07 2016 4:46pm |
Both will charge an iphone for example, but the 2.1 will do it quicker, also would be the one you'd use for iPad's etc, though they would usually draw even more.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
This is what I did, fitted it in Glove box and connected to fuse box via a rocker switch so can switch in on and off as needed and phone can be left on charge out of site.
Wed Sep 07 2016 6:43pm |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Hi, not sure if this will help in anyway but thought I'd add it for you. http://www.ebay.co.uk/itm/HitCar-Car-DC-12...1935055293 |
Wed Sep 07 2016 7:54pm |
Wed Sep 07 2016 9:47pm |
many thanks for the input! I'm currently looking for a usb adaptor that can be hard wired into the front of the car, however for the rear I'll go for the cigarette lighter route as suggested. I hope to post some pics along the way. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Wed Sep 07 2016 10:30pm |
Here are two options for you:
Thu Sep 08 2016 4:36am |
Thanks chaps, much appreciated. I ordered a flush mounted USB charger from Powerful this morning:
Thu Sep 08 2016 10:12am |
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 |
Hey Col, that looks a really nice job. Well done |
Thu Sep 08 2016 10:23am |
Agreed, tastefully done ON THE WAY: BMW F21 M140i
Thu Sep 08 2016 11:27am |
