![]() | Home > General (L494) > Squeaky wheels/brakes on rotation |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
nja, how old is your car and what is the mileage? Do you have Brembo's fitted? |
nja123 Member Since: 03 Jun 2016 Location: UK Posts: 33 ![]() ![]() |
Jim...it was 4 months old when it went in to get fixed, 6500 miles and yes, Brembo. |
I don't understand why there is now a problem with the Brembo set up on the rear wheels now?
Rear? |
Been advised by the service department tghey are fitting "modified brake pads" to cure the brake squeak. Probably same fix as others. Will see if it works when I get the car back. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Hi fkarim...in my case the modified pads didn't work either, i needed the modified-modified pads |
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 ![]() ![]() |
As per my post above - pads changed twice and discs also changed - squeak came back again! |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 ![]() |
Mine is in the dealer now.
Oh...you've got the modified-modified like me! |
Yes shaved pads V2 |
If you search for 'RRS Brake Squeak 2' in youtube you'll hear mine pre botched pads...it's a characteristic of the car my |
Mine went in for the day on Thursday, for the 3rd time since I picked the car up in June.
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 ![]() ![]() |
Maybe it is the front left its hard to pinpoint. Mine isn't all the time though only when coming to a stop at slow speed. |
Mine was also only on light braking at slow speeds. Fixed after "modified" pads. For now at least. Only picked up the car yesterday so not sure if the fix will last. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
