Home > General > swaying while driving on uneven road surface |
Welcome to the forum Mark, I hope the following isn't too much bad news...........
Wed Jul 06 2016 9:51am |
marka Member Since: 06 Jul 2016 Location: weybridge Posts: 6 |
Hi Tim
Wed Jul 06 2016 1:43pm |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
Before changing steering rack I would get tie rod ends checked
Wed Jul 06 2016 3:07pm |
Thanks Alpaca, will do |
Wed Jul 06 2016 3:19pm |
m3virus Member Since: 18 Sep 2013 Location: birmingham Posts: 36 |
Check your tyre pressure or could need tracking👍 Current 55 reg 2.7tdvs with Hst extras |
Wed Jul 06 2016 6:59pm |
Thanks
Wed Jul 06 2016 7:03pm |
Also check the ride heights. From the centre of the wheel to the wheel arch directly above it should be 466 rear and 465 front or thereabouts. Bodsys Brake Bible
Wed Jul 06 2016 7:47pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
You say you just brought it, was it private or from a dealer?
Wed Jul 06 2016 7:49pm |
Double post... |
Wed Jul 06 2016 7:50pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Are the Lower arms ok 61 AB 5.0 supercharged rocket
Wed Jul 06 2016 8:13pm |
It was a private sale, the chap did say he had lowered the suspension by 30mm , would this make a difference ? |
Thu Jul 07 2016 6:01am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Almost certainly, especially if he didn't get the alignment sorted out too. Even with the alignment done it'll probably still be bad.
Thu Jul 07 2016 8:18am |
Thanks for all the info evryone, this is a great forum |
Thu Jul 07 2016 9:53am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Resurrecting an old post as I’ve got a steering wander issue. Obviously I’ve had the alignment checked - it’s currently being looked at for the third time after having it up in the air to check all bushes and joints, which are tight.
Fri Dec 08 2017 11:16am |
