![]() | Home > In Car Electronics > HDC Fault, Transmission Fault, Special Programs Not Availab |
Have you got any fault codes? That is always a good place to start if fault not known. John
nas16309 Member Since: 28 Sep 2016 Location: london Posts: 22 ![]() ![]() ![]() |
Hello friends, I drive a 2009 sport.. very grateful to all members who advised on changing brake switch light..which i did avoiding expensive repairs.
Paul_selby Member Since: 05 Sep 2016 Location: North Yorkshire Posts: 35 ![]() ![]() ![]() |
Hi . I know you said you've changed the brake light switch but I would change again . Mine went a week after getting my s/c and as I was used to driving a manual I was maybe a bit too hard on the brakes, as I got the faults after braking quite hard. Have you had it plugged into diagnostics ? |
Thanks mate for reply
Hello there
You need to upload any photos to your gallery and then paste the link in to your post.
Hello Paddi
Now it is not often you'll see the words 'Range Rover' and 'Lidl' used in the same post but it seems the aforementioned discount supermarket is currently selling a smart charger for £13.99 and it is a good one according to a helpful previous post. If you can't make it to Lidl before they sell out then go for the CTEK brand and you need a 5 amp one (mx5.0 model) but they are a bit stronger money at about £50.
R4zb3rry Member Since: 28 Feb 2015 Location: Leicester Posts: 43 ![]() ![]() |
Might be worth looking at the steering wheel angle sensor as I had same messages on mine including the lean when cornering. |
Hi Paddi
Hi
Hello Paddi
I'm worried you may be jumping to conclusions in blaming the brake pedal switch considering you already changed it.
Thanks Paddi
