Home > In Car Electronics > HDC Fault, Transmission Fault, Special Programs Not Availab |
Have you got any fault codes? That is always a good place to start if fault not known. John
Tue Jun 14 2016 6:50pm |
nas16309 Member Since: 28 Sep 2016 Location: london Posts: 22 |
Hello friends, I drive a 2009 sport.. very grateful to all members who advised on changing brake switch light..which i did avoiding expensive repairs.
Sun Oct 02 2016 5:33pm |
Paul_selby Member Since: 05 Sep 2016 Location: North Yorkshire Posts: 35 |
Hi . I know you said you've changed the brake light switch but I would change again . Mine went a week after getting my s/c and as I was used to driving a manual I was maybe a bit too hard on the brakes, as I got the faults after braking quite hard. Have you had it plugged into diagnostics ? |
Sun Oct 02 2016 6:04pm |
Thanks mate for reply
Sun Oct 02 2016 6:35pm |
Hello there
Tue Oct 04 2016 5:03pm |
You need to upload any photos to your gallery and then paste the link in to your post.
Tue Oct 04 2016 5:31pm |
Hello Paddi
Tue Oct 04 2016 5:50pm |
Now it is not often you'll see the words 'Range Rover' and 'Lidl' used in the same post but it seems the aforementioned discount supermarket is currently selling a smart charger for £13.99 and it is a good one according to a helpful previous post. If you can't make it to Lidl before they sell out then go for the CTEK brand and you need a 5 amp one (mx5.0 model) but they are a bit stronger money at about £50.
Tue Oct 04 2016 6:58pm |
R4zb3rry Member Since: 28 Feb 2015 Location: Leicester Posts: 43 |
Might be worth looking at the steering wheel angle sensor as I had same messages on mine including the lean when cornering. |
Tue Oct 04 2016 9:34pm |
Hi Paddi
Hi
Thu Oct 06 2016 9:24am |
Hello Paddi
Tue Oct 11 2016 6:57pm |
I'm worried you may be jumping to conclusions in blaming the brake pedal switch considering you already changed it.
Wed Oct 12 2016 11:33am |
Thanks Paddi
Wed Oct 12 2016 12:10pm |
