Home > Technical > Cam shaft chain? |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
The only problems I've heard about with our beloved TDV8 engines are turbos which when they go can take the engine with them but not heard of any probes connected to the chain, sorry to hear of your loss.. 2008 G4 RRSport TDV8 current
Tue Feb 16 2016 1:38pm |
skirk Member Since: 15 May 2015 Location: Scotland Posts: 4 |
Is there suppose to be a chain on that second cog though? Or does that picture look normal? I will have a look over the turbos and see if they are ok, thanks |
Tue Feb 16 2016 1:57pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
There is one chain per bank driving the inlet camshaft. The exhaust camshaft is driven by cogs from the inlet side. The other cog you see there is one of those drive cogs. 2012 SDV6 - it's missing a couple of cylinders
Tue Feb 16 2016 7:22pm |
