![]() | Home > General > jacking up a rrs |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
You just have to keep jacking away. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Not to sure but wouldn't think to advisable to be jacking on the driveshaft. Cheers Col |
CDS Member Since: 21 Sep 2011 Location: Oldham Posts: 25 ![]() |
Best bet is a 3T trolley jack on a chassis member or a 2T trolley jack on a wish bone (but not the drive shaft)
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
I've heard mention of leaving the boot open while jacking to avoid the suspension resetting itself as you hack. I did although one wheel did lower itself during the process |
The best way to stop the suspension altering while it's in the air is to use axles stands |
This is a (sort of) myth that's developed from a slight misunderstanding. Opening a door (not the taligate though) will prevent the ride height change, however, it does not stop the suspension self-levelling. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
I carry a 6t bottle Jack in the boot now ... |
I think some of that may backdate to the day's of the P38 at least, because I'm sure it said in the Drivers Handbook to open the tailgate to stop suspension lowering. Cheers Col |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 ![]() ![]() ![]() |
I've just been looking at bottle jacks and, unless I'm mistaken, it doesn't look as if they would lift anything like high enough. Most seem to have a maximum height of around 350-400mm and give a lift of just 150mm or so. Does a bottle jack really work? |
I keep one of these in the car: http://www.sgs-engineering.com/tbj10-10-to...ottle-jack It's overkill on the weight side, but it's sturdy and takes no effort to use. |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 ![]() ![]() ![]() |
I just got one for a freind from a Merc Sprinter, small enough and two stage so should do the job and fit in the boot fine. Lot of Landcruisers now sold
Does that reach the chassis ok? Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Yep; being telescopic, there's more than enough height and the screw can be extended to reach the chassis before you've even started jacking. |
