Home > General > jacking up a rrs
benj193
jacking up a rrs
so i had a flat tire over the weekend, and when trying to put on the spare tire, i noticed it was very hard to get the car jacked up correctly.
i have a MY06 and from what i have heard, the jack that comes with the car is very unreliable. when i was jacking up, all that was happening was the suspension was lifting. I then set the car to the highest access height possible and tried again. Still no luck as the suspension just dropped slowly on its own.
The only way i could manage was to use multiple jacks on the back of the car and also one on the driveshaft.
Was i doing anything wrong? or are these cars notorious for difficult wheel changes?
Post #480733 Mon Nov 23 2015 11:08am
Lost for Words
You just have to keep jacking away. Thumbs Up
...and, yes, the supplied jack is not only "unreliable" but downright dangerous. Visiting from DISCO3.CO.UK
Post #480734 Mon Nov 23 2015 11:30am
Re: jacking up a rrs
Not to sure but wouldn't think to advisable to be jacking on the driveshaft.
Post #480738 Mon Nov 23 2015 11:56am
CDS
Best bet is a 3T trolley jack on a chassis member or a 2T trolley jack on a wish bone (but not the drive shaft)
If you are jacking on the chassis the gap between the tyre and the wheel arch is around 18 inches before the wheel leaves the ground Thumbs Up Over for a visit from disco3.co.uk
Post #480742 Mon Nov 23 2015 12:29pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
I've heard mention of leaving the boot open while jacking to avoid the suspension resetting itself as you hack. I did although one wheel did lower itself during the process
Post #480745 Mon Nov 23 2015 1:50pm
CDS
The best way to stop the suspension altering while it's in the air is to use axles stands Rolling with laughter Over for a visit from disco3.co.uk
Post #480746 Mon Nov 23 2015 2:42pm
Lost for Words
This is a (sort of) myth that's developed from a slight misunderstanding. Opening a door (not the taligate though) will prevent the ride height change, however, it does not stop the suspension self-levelling. Thumbs Up Visiting from DISCO3.CO.UK
Post #480748 Mon Nov 23 2015 3:07pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
I carry a 6t bottle Jack in the boot now ...
Post #480793 Tue Nov 24 2015 6:24am
I think some of that may backdate to the day's of the P38 at least, because I'm sure it said in the Drivers Handbook to open the tailgate to stop suspension lowering.
Post #480794 Tue Nov 24 2015 7:12am
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
I've just been looking at bottle jacks and, unless I'm mistaken, it doesn't look as if they would lift anything like high enough. Most seem to have a maximum height of around 350-400mm and give a lift of just 150mm or so. Does a bottle jack really work?
Post #480798 Tue Nov 24 2015 9:37am
Lost for Words
I keep one of these in the car: http://www.sgs-engineering.com/tbj10-10-to...ottle-jack It's overkill on the weight side, but it's sturdy and takes no effort to use. Thumbs Up
There's also a smaller 5-ton version: http://www.sgs-engineering.com/garage-equi...ottle-jack Wink Visiting from DISCO3.CO.UK
Post #480800 Tue Nov 24 2015 9:49am
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I just got one for a freind from a Merc Sprinter, small enough and two stage so should do the job and fit in the boot fine. Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #480811 Tue Nov 24 2015 12:30pm
DrRob
Does that reach the chassis ok? Visitor from fullfatrr.com
Post #481153 Sun Nov 29 2015 9:01am
DrRob
Post #481154 Sun Nov 29 2015 9:03am
Lost for Words
Yep; being telescopic, there's more than enough height and the screw can be extended to reach the chassis before you've even started jacking. Thumbs Up Visiting from DISCO3.CO.UK
Post #481155 Sun Nov 29 2015 9:30am
