Home > My Range Rover Sport > Conversion.
Page 4 of 9 <123456789>
ABSport
To answer your questions if you have been offered a 2012 interior the seats and door cards will all fit no problem. The rear dvd screens won't work as you don't have the harness (cables ) they could probably be retrofitted Whistle if it has the rotary dial (gear-knob) that won't work as it is electronic and 8 speed auto.
Post #459552 Fri Apr 17 2015 7:20pm
newlove2003
Hi ive just spoken to the person and he said the seats come with everything needed for the tv's to work, been reading a little do i after get it coded at land rover?
could you give me the list of stuff which should come with it for them to work so i can make sure he as the lot. sorry for all the questions again thank you
Post #459574 Fri Apr 17 2015 8:50pm
Freshmaker
United States 2008 Range Rover Sport Supercharged Buckingham Blue
ABSport wrote:
Hi it's the complete unit cost is around £250 from dealer. Embarassed
Hi ABSport,
Great job on the conversion. Love that you kept everything OEM. Quick question on the chrome surround with the suspension switch. Does the DSC button right below the hill descent button work on your panel? The reason i ask is because on 2010 and 2011 the DSC button is right next to the button for heated seats which was replaced by the power tailgate button on 2012 and 2013. Im looking to replace the unit on my 2011 RRS SC as i like it better than the grey version with the rotary dial. Just wanted to make sure that its not going to throw any codes as I'm still under warranty. Thanks in advance for your response.
Post #459703 Sun Apr 19 2015 3:28am
ABSport
Hi everything works on it as it should, however as you say the DSC button is on the dash. There are two versions of the panel as mine is a SE model I opted for the basic standard gear surround. This way it was just plug and play. I know there is a different one which incorporates 1 more switch.
Your dealer will be able to help you with which one you require. Thumbs Up
Post #459706 Sun Apr 19 2015 6:50am
Freshmaker
Thank you for your prompt reply. Since i have a supercharged with adaptive dampening i will have to get the second version LR044983. Most parts websites and the dealer said that it is compatible with the 2011 and 2010 version but the DSC button probably will be non functional as its on the dash itself.
Post #459821 Mon Apr 20 2015 1:29am
Freshmaker
I also have one more question - Did you have to remove the steering wheel to replace the wiper and the turn signal stalks or is it as easy as removing the top and the bottom cover behind the steering wheel to replace them?
Thanks
Post #459822 Mon Apr 20 2015 2:31am
ABSport
Hi just remove the top and bottom cover and each stalks are held in with 2 small screws they just push in and out. Hope that helps Thumbs Up
Post #459824 Mon Apr 20 2015 6:48am
Freshmaker
Thank again for your help. I got the stalks installed without any issues. Now I'm working on installing the gear surround.
Post #460293 Thu Apr 23 2015 9:35pm
Freshmaker
nashvegas wrote:
ABSport wrote:
Hi nashvegas
Yes it is a direct replacement I also did not like the rotary switch. The newer "rocker lever" looks so much better, only problem is this is very expensive even with my trade discount from Land Rover it was still £230. Shocked however the grey trim around the cup holder and gearstick was £40. This is a little bit more fiddly to replace Whistle
That is superb news! I am going to try it. I wonder what it might look like to keep the metal / noble trim and add the 2012 shifter surround (maybe good... I'll try it and post up)
Also - one question - I realized that the DSC button which on the 2010 is replaced by the liftgate button on the 2012 has moved down to the shift surround. What happens if you press that button on your 2011 w the conversion?
Hi nashvegas,
Did you end up getting the chrome surround with the buttons instead of the rotary dial? If so can u post some pics?
Just want to see what it will look like with the noble trim.
Thanks
Post #460315 Fri Apr 24 2015 8:47am
Freshmaker
I got one more question for you - Im getting the gear surround with the suspension switch delivered in a few days. I can see that the gear shifter knob needs to be removed to remove the panel (i found videos on youtube regarding the removal of gear knob). Does the surround panel have screws or is it held together via clips. I just want to make sure that i don't break any clips when removing and installing the new one.
Thanks again for your assistance.
Post #460611 Mon Apr 27 2015 7:55pm
ABSport
It has 2 screws underneath Crying or Very sad where the Range Rover emblem is they are directly beneath that. The only way to get to them is the top part of your centre consul has to be removed and you'll be able to undo the screws. Bit of a ball ache but be careful not to scratch or mark anything.
TIP, where you insert a CD you need to unclip the plastic cover and you'll see 2 small screws remove them and the consul will be able to be removed. Thumbs Up
Post #461178 Tue May 05 2015 7:15am
Dave435
Scotland 2008 Range Rover Sport TDV8 HST Java Black
Very nice always liked the autobiography! Very Happy
Post #461444 Thu May 07 2015 8:28pm
JoKa
Finland
Nice job!
Post #461616 Sat May 09 2015 1:40pm
Baron
That is most impressive Bow down Bow down Bow down  SDV8 vogue SE.
Corris grey and ivory leather + most of the toys.
Limited edition RRS model number 0001 Smile
Gone TDV8 RR Sport. Never to be forgotten.
Wife has an i8 BMW
Post #461844 Wed May 13 2015 7:13pm
ABSport
Thank you Sir. Thumbs Up
Post #461854 Wed May 13 2015 8:12pm
