Home > My Range Rover Sport > Conversion. |
newlove2003 Member Since: 16 Apr 2015 Location: west yorkshire Posts: 24 |
Hi ive just spoken to the person and he said the seats come with everything needed for the tv's to work, been reading a little do i after get it coded at land rover?
Fri Apr 17 2015 7:50pm |
Freshmaker Member Since: 22 Sep 2012 Location: Reno,NV Posts: 8 |
Hi ABSport, Great job on the conversion. Love that you kept everything OEM. Quick question on the chrome surround with the suspension switch. Does the DSC button right below the hill descent button work on your panel? The reason i ask is because on 2010 and 2011 the DSC button is right next to the button for heated seats which was replaced by the power tailgate button on 2012 and 2013. Im looking to replace the unit on my 2011 RRS SC as i like it better than the grey version with the rotary dial. Just wanted to make sure that its not going to throw any codes as I'm still under warranty. Thanks in advance for your response. |
Sun Apr 19 2015 2:28am |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Hi everything works on it as it should, however as you say the DSC button is on the dash. There are two versions of the panel as mine is a SE model I opted for the basic standard gear surround. This way it was just plug and play. I know there is a different one which incorporates 1 more switch.
Sun Apr 19 2015 5:50am |
Thank you for your prompt reply. Since i have a supercharged with adaptive dampening i will have to get the second version LR044983. Most parts websites and the dealer said that it is compatible with the 2011 and 2010 version but the DSC button probably will be non functional as its on the dash itself. |
Mon Apr 20 2015 12:29am |
I also have one more question - Did you have to remove the steering wheel to replace the wiper and the turn signal stalks or is it as easy as removing the top and the bottom cover behind the steering wheel to replace them?
Mon Apr 20 2015 1:31am |
Hi just remove the top and bottom cover and each stalks are held in with 2 small screws they just push in and out. Hope that helps |
Mon Apr 20 2015 5:48am |
Thank again for your help. I got the stalks installed without any issues. Now I'm working on installing the gear surround. |
Thu Apr 23 2015 8:35pm |
Hi nashvegas, Did you end up getting the chrome surround with the buttons instead of the rotary dial? If so can u post some pics? Just want to see what it will look like with the noble trim. Thanks |
Fri Apr 24 2015 7:47am |
I got one more question for you - Im getting the gear surround with the suspension switch delivered in a few days. I can see that the gear shifter knob needs to be removed to remove the panel (i found videos on youtube regarding the removal of gear knob). Does the surround panel have screws or is it held together via clips. I just want to make sure that i don't break any clips when removing and installing the new one. Thanks again for your assistance. |
Mon Apr 27 2015 6:55pm |
It has 2 screws underneath where the Range Rover emblem is they are directly beneath that. The only way to get to them is the top part of your centre consul has to be removed and you'll be able to undo the screws. Bit of a ball ache but be careful not to scratch or mark anything.
Tue May 05 2015 6:15am |
Dave435 Member Since: 14 Jul 2014 Location: Aberdeen Posts: 40 |
Very nice always liked the autobiography! |
Thu May 07 2015 7:28pm |
JoKa Member Since: 29 Mar 2015 Location: Helsinki Posts: 36 |
Nice job! |
Sat May 09 2015 12:40pm |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 |
That is most impressive SDV8 vogue SE.
Wed May 13 2015 6:13pm |
Thank you Sir. |
Wed May 13 2015 7:12pm |
