![]() | Home > My Range Rover Sport > Conversion. |
imb111 Member Since: 30 Nov 2012 Location: UK Posts: 28 ![]() ![]() |
wow very impressive |
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 ![]() ![]() |
brilliant conversion well done , what did you need to change except the door handles to get the lock/ unlock buttons to work on the outer door handles cheers . |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Hi as I had removed the interior from a 2012 Autobiography the door cards had the door modules in them, with this I removed the handles and fitted them. I only replaced the external covers as 3 of them were scratched. They are only clipped in on the facelift models |
So the wiring was already there to plug the outer handles into? |
The wiring from the door handle plugged into each door module. |
Ok thanks will have a look . |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
Sensational work... amazing result... Great thread .. Thx 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
markryan15 Member Since: 30 Oct 2015 Location: Virginia, USA Posts: 22 ![]() ![]() ![]() |
Do you happen to know if the 2012 turn signal and windshield wiper levers will work on a 2008 RRS? |
Range_Driver Member Since: 12 Aug 2014 Location: Stockholm Posts: 4 ![]() ![]() ![]() |
Hi ABSPORT,
***Update***
Update on thread.
How'd did you wire it to open? |
Hi it's wired to open the same way as the 2012, the boot release above the number plate still opens the tailgate and also opens via one press on the key fob. |
Newstuart Member Since: 21 Feb 2016 Location: Northumberland Posts: 35 ![]() ![]() |
can anyone else see more than the first 4 pictures? Looks great from what I can see but only the first 4 load up for me |
