![]() | Home > Faults & Fixes > Tdv8 - Engine system failure - limp mode |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9058 ![]() ![]() ![]() |
Those error codes (they're not complete LR codes as they are missing two numbers at the end) indicate turbo boost issues.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4460 ![]() ![]() ![]() |
A split turbo hose will also log turbo codes |
Useful to know, thanks |
megablade Member Since: 16 Feb 2012 Location: UK Posts: 3 ![]() |
Really hoping so. Mate said he couldn't hear any 'hissing' though.
D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183 ![]() ![]() ![]() |
Same fault flagged up on my tdv6, and cars gone into limp mode.
Ended up being my alternator, so check that 1st.
austencameron Member Since: 11 Apr 2012 Location: Fife Posts: 41 ![]() ![]() ![]() |
actuators on the turbos could be seized, u can access them from underneath, spent time with wd40 and moving the actuator rod up and down.
Actuator arms/joints lubed plus found a split hose. Job done! Thanks. |
