Home > Faults & Fixes > Tdv8 - Engine system failure - limp mode |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Those error codes (they're not complete LR codes as they are missing two numbers at the end) indicate turbo boost issues.
Thu Jan 29 2015 9:55pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
A split turbo hose will also log turbo codes |
Thu Jan 29 2015 10:35pm |
Useful to know, thanks
Thu Jan 29 2015 10:55pm |
megablade Member Since: 16 Feb 2012 Location: UK Posts: 3 |
Really hoping so. Mate said he couldn't hear any 'hissing' though.
Thu Jan 29 2015 11:01pm |
D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183 |
Same fault flagged up on my tdv6, and cars gone into limp mode.
Sat Jan 31 2015 4:00pm |
Ended up being my alternator, so check that 1st.
Thu Feb 12 2015 10:44am |
austencameron Member Since: 11 Apr 2012 Location: Fife Posts: 41 |
actuators on the turbos could be seized, u can access them from underneath, spent time with wd40 and moving the actuator rod up and down.
Thu Feb 12 2015 1:22pm |
Actuator arms/joints lubed plus found a split hose. Job done! Thanks. |
Mon Jul 06 2015 9:58pm |
2012 SDV6 - it's missing a couple of cylinders
Tue Jul 07 2015 6:51am |
