Home > Faults & Fixes > Tdv8 - Engine system failure - limp mode
megablade
Hi chaps,
Hoping someone can help me please.
2007 RRS TDV8 in limp mode and sounding lumper than normal (not smoking)
Codes read as P132b and P138e
cleared codes and restarted and sounded normal again but threw ! Message(engine system failure) and back to limp mode and lumpy as soon as I pulled away.
Mate has checked actuator arms and in his words they are both free as a bird! (Moving them manually)
Have left turbo replaced 5000 miles ago and mechanic checked right one over and said there wasn't anything wrong with it.
Any thoughts?
Barry
Post #450289 Thu Jan 29 2015 8:43pm
Those error codes (they're not complete LR codes as they are missing two numbers at the end) indicate turbo boost issues.
They both refer to the right hand turbo.
You need to get the full LR DTC code read to help pin down the exact issue but I bet it's the actuator that's the problem. 2012 SDV6 - it's missing a couple of cylinders
Post #450307 Thu Jan 29 2015 10:55pm
Disco_Mikey
A split turbo hose will also log turbo codes Thumbs Up
Post #450313 Thu Jan 29 2015 11:35pm
Useful to know, thanks Thumbs Up
Would be nice for the OP if it's something as simple as a split hose... 2012 SDV6 - it's missing a couple of cylinders
Post #450314 Thu Jan 29 2015 11:55pm
megablade
Really hoping so. Mate said he couldn't hear any 'hissing' though.
When last turbo went it went with a pop and luckily switched off in time. This is still running, so if it is turbo, there are different ways that they can fail?
Post #450315 Fri Jan 30 2015 12:01am
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Same fault flagged up on my tdv6, and cars gone into limp mode.
Had it read by a snap on scanner, didnt really say much,
So booked it in with a local land rover specialist.
Hope it something as a broken hose or similar and not the turbo.
Post #450561 Sat Jan 31 2015 5:00pm
D12TYJ
Ended up being my alternator, so check that 1st.
Slightest voltage drop will make the car go into limp mode
Post #452321 Thu Feb 12 2015 11:44am
austencameron
actuators on the turbos could be seized, u can access them from underneath, spent time with wd40 and moving the actuator rod up and down.
I had that fault code last year and cured the problem.
Post #452328 Thu Feb 12 2015 2:22pm
megablade
Actuator arms/joints lubed plus found a split hose. Job done! Thanks.
Post #466756 Mon Jul 06 2015 10:58pm
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #466779 Tue Jul 07 2015 7:51am
