Home > Maintenance & Modifications > Quick compressor fix question |
Dannutt Member Since: 06 Jan 2014 Location: Bucks Posts: 60 |
Stupid really but when I take the compressor off for the refurb does the car have to be in access mode to stop it dropping down suddenly when I disconnect the hoses or car I have it raised up in full 4x4 mode? I'm guessing access.
Tue Sep 09 2014 7:09pm |
Huh yeah first time I tried to jack it up to change the brake wear cable that wheel just rose into the sky for about 5 minutes
Tue Sep 09 2014 7:42pm |
IF you can get the bolts off, then def recommend the full kit. You will be able to change the piston seal and carbon ring without too much difficulty. Problem is with the exhaust spring and rubber plunger, the bolt can become corroded to the case.
Tue Sep 09 2014 7:52pm |
Are the odds pretty good everything will come apart?
Tue Sep 09 2014 8:05pm |
Ah hold on, that's a different kit. It fixes the popular crack in the air dryer unit (LR have stopped supplying the dryer on its own for £70 and have superseded the part with the new compressor at £500!!!)
Tue Sep 09 2014 8:44pm |
In fact, your best off taking this repair service.
Tue Sep 09 2014 8:51pm |
No can do Im afraid. It means leaving Mrs Dan and the baby without a car for several days. I need to plan around doing it over the weekend.
Tue Sep 09 2014 9:05pm |
Presumably Mrs Dan wouldn't be able to use the car whilst the pump was away? |
Tue Sep 09 2014 9:10pm |
Not really. Bodsys Brake Bible
Tue Sep 09 2014 9:37pm |
For a few quid you could hire a Fiesta or other small motor to keep the family mobile then you'd buy yourself time to do what's best ! |
Wed Sep 10 2014 7:49am |
I hear ya but that rebuild is £150+26p&p so now your getting on for half the price of a new replacement.....
Wed Sep 10 2014 5:39pm |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 152 |
hi
Wed Sep 24 2014 8:35pm |
